[Qgis-user] Struggling with the field calculator
Hanlie Pretorius
hanlie.pretorius at gmail.com
Tue Apr 2 19:44:13 PDT 2013
I'm using QGIS 1.8.0 on Windows 7.
I have a shapefile with some Real attribute columns (Length 19, precision
10) and I want to create a percentage column from two of these.
So I start editing the file, open the attribute table and open the field
calculator.
Then I create a new field with the same data type (Real, length 19,
precision 10) and I use the GUI and field selectors to enter the following
expression:
"S2" / "GVA09" * 100
This works fine until I try to save the changes or stop editing. Then all
values in the new column revert to 0 or NULL.
Does someone know what is going on?
Thanks
Hanlie
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130403/ce3c9221/attachment.html>
