[Qgis-user] NoData on GRASS Raster
Radim Blazek
radim.blazek at gmail.com
Fri Apr 5 03:20:20 PDT 2013
On Thu, Apr 4, 2013 at 1:42 PM, Timmie <timmichelsen at gmx-topmail.de> wrote:
> Hello,
> I have loaded a GRASS raster directly by opening the mapset.
> In GRASS maps itself the NoData, i.e. null(), cells are left transparet.
> In QGis these are shown with the colour of the most inferior class.
No data values should be transparent by default. If not, it is a bug,
please fill a new bug report.
> How can I get them to be transparent?
> In the transparency settings (next tab in properties dialogue), only
> numerical values are allowed for the NoData field.
No data values are represented internally by a numerical value, you
can try to find the no data value (in general tab) and use it in
transparency but that is just a workaround.
Do you see a no data value in "No data value" group box in
transparency tab? Is it checked? What identify tool says for your no
data pixels?
Radim
> A similar dicusssion:
> http://osgeo-org.1560.n6.nabble.com/No-data-value-in-raster-transparency-list-td4997078.html
> Thanks inadvance for your help,
> Timmie
> Qgis-user mailing list
