[Qgis-user] Geoprocessing - Intersect points within Ploygon
Gibbons, John
John.Gibbons at salford.gov.uk
Fri Apr 5 07:01:57 PDT 2013
I'm try to create a list of points that exist within polygons. I have a delimited text layer for the points, and a shape file of polygons.
I've used Geoprocessing, Intersect off the Vector menu, specified the point layer first and polygon layer second. Although it creates a shape file, it has nothing in the resulting attribute table. I've tried different point and layer files, but still had no results.
I notice that I can carry out an intersect between two polygon layers, in this case, the attribute table has results.
I converted my point layer to to a shape file, ran the intersect again, but still no output.
There are points in the polygons(!), and the CRS match.
Can anyone advise?
DISCLAIMER: The information contained in this communication/message from John.Gibbons at salford.gov.uk sent on Fri Apr 5 15:01:58 2013 is confidential and may be legally privileged. It is intended solely for the addressee(s) qgis-user at lists.osgeo.org
Access to this message by anyone else is unauthorised. If you are not the intended recipient, any disclosure, copying, or distribution of the message, or any action or omission taken by you in reliance on it, is prohibited and may be unlawful.
As a public body, Salford City Council may be required to disclose this email [or any response to it] under the Freedom of Information Act 2000, unless the information in it is covered by one of the exemptions in the Act.
Please immediately contact the sender, John.Gibbons at salford.gov.uk if you have received this message in error.
For the full disclaimer please access http://www.salford.gov.uk/e-mail. Thank you.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130405/86138214/attachment.html>
