[Qgis-user] SAGA-GIS on OS X 10.7
Agustin Diez-Castillo
gvsig.mac at gmail.com
Mon Apr 15 04:32:03 PDT 2013
Dear all,
After some success installing SAGA, I've tried editing SagaUtils.py and
hard coding the SAGA_FOLDER to /usr/local/bin with not success. Having not
knowledge of python, it seems to me that the following else clause should
work in mac as well.
if SextanteUtils.isMac():
testfolder = os.path.join(str(QgsApplication.prefixPath()),
"bin")
if os.path.exists(os.path.join(testfolder, "saga_cmd")):
folder = testfolder
else:
testfolder = "/usr/local/bin"
folder = testfolder
and the same in the next call to Mac
elif SextanteUtils.isMac():
fout.write("export SAGA_MLB=" + SagaUtils.sagaPath() +
"/../lib/saga\n");
fout.write("export PATH=" + SagaUtils.sagaPath() + ":$PATH\n");
else:
pass
for command in commands:
fout.write("saga_cmd " + command.encode("utf8") + "\n")
In this case I have doubts if SAGA_MLB should be "../lib/saga\n" instance
of ""/../lib/saga\n"
I've tested most of the above option with no success whatsoever
Error messages are not always the same but the further I get is to:
Error while checking SAGA installation. SAGA might not be correctly
configured.
File
"/Applications/QGIS_2.0-dev.app/Contents/Resources/python/plugins/sextante/saga/SagaUtils.py",
line 146, in checkSagaIsInstalled
from sextante.core.Sextante import runalg
ImportError: cannot import name runalg
Best
On Thu, Apr 4, 2013 at 9:58 PM, William Kyngesburye
<woklist at kyngchaos.com>wrote:
> On Apr 4, 2013, at 2:33 PM, gvSIGMac wrote:
> > Thanks William,
> > On 10.8 I can't compile because there is not autoconf available. See
> inline comments below.
> That's part of what the instructions cover - installing the autotools.
> Anyways, I've been working on a packaging plan for saga within qgis. I
> just got to the point of testing it, and it looks like Sextante does not
> care if the saga tools are in the current PATH (ie the QGIS bin folder), it
> requires a saga path to be configured in Sextante. Problem is, there is a
> saga path option in the code, but there is no way to configure it in the
> Sextante preferences dialog box. Orfeo and GRASS both have the preferences
> to set their paths, so this must be an oversight.
> > ________________________________
> > Agustin
> > On 04/04/2013, at 19:10, William Kyngesburye <woklist at kyngchaos.com>
> wrote:
> >> On Apr 4, 2013, at 7:52 AM, Agustin Diez-Castillo wrote:
> >>> Other approaches compile in 10.7. Thanks William
> >>>> SDKs are really only needed when you compile on one system for an
> earlier system, like on Lion (10.7) for >Snow Leopard (10.6)
> >>> So, maybe my first compilation should work with 10.6 and 10.8. I did
> check both with no stable results.
> >> The binaries created should not work on 10.6 because you used a 10.7
> SDK. It should work on 10.8. The compilation method should work on all
> systems as long as the SDK, macosx-version-min and CXX options are adjusted
> to match (no need to set CXX on 10.6).
> >>> I prepared a package [1] in case anyone want to test this.
> >>> Anyhow, if we're discussing that here is because we want to use SAGA
> via SEXTANTE in Qgis and there I have no success whatsoever. In my system,
> saga_cmd works but Qgis tells me that the SAGA installation maybe is not
> correct. I did put /usr/local/lib/saga on my path as well.
> >> How did you add it to your path? Adding it to .bash_profile will not
> work. And that's the wrong path anyways, it should be /usr/local/bin.
> > I added both to .bash_profile
> >> If QGIS can't find /usr/local/bin without help (no way to do that in
> QGIS 1.8, unless Sextante has a configuration option for the SAGA path),
> one way would be to compile directly into the QGIS app. Add to the SAGA
> configure command:
> >> --prefix=/Applications/QGIS.app/Content/MacOS
> > I did something like that to build my saga but did not think about
> putting this in QGIS. So maybe you can build QGIS with saga in the near
> future?
> > --prefix=/Applications/SAGA.app
> >> it will then install into the QGIS app bin/ folder which QGIS/Sextante
> should find automatically. Though you can't move or rename QGIS now or it
> will break SAGA.
> >>> There are other issues when running SAGA but I guess those belong to
> the SAGA list.
> >>> Agustin
> >>> [1] https://www.dropbox.com/s/ufzsq7h826jp4u8/SAGA21.dmg
> >>> On Thu, Mar 28, 2013 at 12:35 AM, William Kyngesburye <
> woklist at kyngchaos.com> wrote:
> >>> OK. 2 simple choices of solutions:
> >>> Don't use a SDK. SDKs are really only needed when you compile on one
> system for an earlier system, like on Lion (10.7) for Snow Leopard (10.6),
> or when only the Xcode app is used (ie with an Xcode project). With this,
> just remove the -isysroot up to .sdk in the configuration.
> >>> Or if you need the SDK, add "-F /Library/Frameworks" to LINK_MISC.
> The documentation for the isysroot flag appears to be a little misleading.
> It says that the sysroot specified is added to all search paths, but I
> think it really means all search paths that are within the scope of the
> SDK. /Library is not. But /usr is, so it would still catch /usr/local, so
> the wx libraries would be a problem...
> >> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> >> http://www.kyngchaos.com/
> >> First Pogril: Why is life like sticking your head in a bucket filled
> with hyena offal?
> >> Second Pogril: I don't know. Why IS life like sticking your head in a
> bucket filled with hyena offal?
> >> First Pogril: I don't know either. Wretched, isn't it?
> >> -HitchHiker's Guide to the Galaxy
> Earth: "Mostly harmless"
> - revised entry in the HitchHiker's Guide to the Galaxy
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130415/8b91017d/attachment.html>
