[Qgis-user] opening multitable postgis view is slow
Lassche, M.R. m.r.lassche at vu.nl
Wed Apr 17 01:41:46 PDT 2013
Bernard,
Yes there are spatial indexes in place. The get extent is slow because building the result set for the whole table (9 million rows with point geometry) is slow.
What I do now is a multi step approach
1 - alter the query in such a way that no rows are returned - simple by adding a where condition that is never true e.g where 1=2
2- opening the layer in QGis, gives me no results
4 - zoom in to the desired region
5 - alter the view so the query does return rows
6 - refresh the data layer.
This does work, but is kind of a hassle.
Ronnie
-----Oorspronkelijk bericht-----
Van: Bernhard Ströbl [mailto:bernhard.stroebl at jena.de]
Verzonden: woensdag 17 april 2013 10:29
Aan: qgis-user at lists.osgeo.org
Onderwerp: Re: [Qgis-user] opening multitable postgis view is slow
Hi Ronnie,
do you have a spatial index on the geometry columns of the tables contained in the view?
(just guessing)
Bernhard
Am 17.04.2013 10:26, schrieb Lassche, M.R.:
> Hi all,
> When loading multi table views in QGis it always starts with determining the extent of the result set.
> With pg_stat_activity you can see the following query running for a long time: SELECT st_extent("geom") FROM "bag"."vw_bag_pand_functie"
> Does anyone has ideas of how to speed up the loading this dataset in QGis. The view is as efficient as can be, it will normally returns something like 9 million rows for the whole of the Netherlands, but normally I zoom in to a region of interest and then there is no need of first establishing the extent of the whole data set.
> All suggestions are welcome
> Ronnie
__________ Information from ESET Mail Security, version of virus signature database 8236 (20130417) __________
The message was checked by ESET Mail Security.
http://www.eset.com
