[Qgis-user] Pass attribute in QML styling file
Nathanael Boehm nboehm at purecaffeine.com
Thu Apr 18 18:06:42 PDT 2013
Never mind thanks, I found the Rendering Order dialog which mentions
rendering "passes" so I figured that's what the attribute correlates to
(and explains why doing the outline in a consecutive pass means your inner
lines all connect nicely).
QGIS is pretty awesome, good work to the dev community :)
Nathanael Boehm
UX designer specialising in business web & mobile apps
www.purecaffeine.com <http://www.purecaffeine.com/professional/>
Canberra, Australia
On Fri, Apr 19, 2013 at 9:49 AM, Nathanael Boehm <nboehm at purecaffeine.com>wrote:
> Hi,
> Just started playing with QGIS yesterday after evaluating a bunch of
> different apps for learning cartography and GIS, mostly as a hobby but also
> as a specialist skillset for my user experience design work.
> I'm currently on 1.9 and couldn't figure out why adding outlines on lines
> (by having a thicker line underneath) resulted in every line being capped
> like the image on the left at the link below … yet when I examined Anita
> Graser's light style file for OSM the only real difference was the pass="1"
> attribute on the layer element, which I copied and then got the result on
> the right (which is what I wanted).
> http://twitpic.com/ckarya
> So … what is this 'pass' attribute, and why can't it be modified in the UI?
> Cheers,
> Nathanael Boehm
> Canberra, Australia
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130419/688989ac/attachment.html>
