[Qgis-user] Error when using SAGA & SEXTANTE with QGIS 1.9
Nyx nyxynyx at gmail.com
Sat Apr 20 07:16:39 PDT 2013
Hi everyone, I am trying to use some SAGA function (IDW) using QGIS 1.9
298f0c0  and the SEXTANTE plugin. SAGA 2.1 b3 64bit has already been
installed and the OS is Windows 8.
When I activate SAGA from the SEXTANTE options, I find in the error logs 2
logs of:
Could not load model watersheds.model
ALGORITHM:ftools:export/addgeometrycolumns
Next when I select SAGA's Inverse Distance Weighted function within
Sextante, and use the default values for the parameters, I get an error
popup saying:
Could not load layer
C:\Users\me\AppData\Local\Temp\sextante\sagainversedistanceweighted......tif.
Check the SEXTANTE log to look for errors.
In the SEXTANTE logs I find the following logs.
Any ideas how we can get SEXTANTE to work? Thank you!!
SAGA execution console output
C:\>set SAGA=C:\Program Files\saga
C:\>set SAGA_MLB=C:\Program Files\saga\modules
C:\>PATH=PATH;C:\Program Files\saga;C:\Program Files\saga\modules
C:\>saga_cmd grid_gridding "Inverse Distance Weighted" -SHAPES
"C:/Users/me/Desktop/test/Scores/MA Full/Scores.shp" -FIELD "score" -TARGET
0 -WEIGHTING 0 -POWER 2 -BANDWIDTH 1 -RANGE 0 -RADIUS 100 -MODE 0 -POINTS 0
-NPOINTS 10 -USER_XMIN 2135073.26163 -USER_XMAX 2442654.3611 -USER_YMIN
20206.1478731 -USER_YMAX 185532.363448 -USER_SIZE 0 -USER_GRID
"C:\Users\me\AppData\Local\Temp\sextante\sagainversedistanceweightedafef52b8ebe84495ac957c5155bd7f0a.tif.sgrd"
Unknown option 'POWER'
Usage: saga_cmd -SHAPES <str> [-FIELD <str>] [-TARGET <str>] [-SEARCH_RANGE
<str>] [-SEARCH_RADIUS <str>] [-SEARCH_POINTS_ALL <str>]
[-SEARCH_POINTS_MAX <num>] [-SEARCH_DIRECTION <str>] [-WEIGHTING <str>]
[-WEIGHT_POWER <str>] [-WEIGHT_BANDWIDTH <str>] [-USER_XMIN <str>]
[-USER_XMAX <str>] [-USER_YMIN <str>] [-USER_YMAX <str>] [-USER_SIZE <str>]
[-USER_GRID <str>] [-GRID_GRID <str>]
-SHAPES:<str>           Points
Shapes (input)
-FIELD:<str>             Attribute
Table field
-TARGET:<str>           Target Grid
Choice
Available Choices:
[0] user defined
[1] grid
-SEARCH_RANGE:<str>     Search Range
Choice
Available Choices:
[0] local
[1] global
-SEARCH_RADIUS:<str>     Maximum Search Distance
Floating point
Minimum: 0.000000
-SEARCH_POINTS_ALL:<str> Number of Points
Choice
Available Choices:
[0] maximum number of nearest points
[1] all points within search distance
-SEARCH_POINTS_MAX:<num> Maximum Number of Points
Integer
Minimum: 1.000000
-SEARCH_DIRECTION:<str> Search Direction
Choice
Available Choices:
[0] all directions
[1] quadrants
-WEIGHTING:<str>         Distance Weighting
Choice
Available Choices:
[0] inverse distance to a power
[1] linearly decreasing within search radius
[2] exponential weighting scheme
[3] gaussian weighting scheme
-WEIGHT_POWER:<str>     Power
Floating point
-WEIGHT_BANDWIDTH:<str> Bandwidth
Floating point
Minimum: 0.000000
-USER_XMIN:<str>         Left
Floating point
-USER_XMAX:<str>         Right
Floating point
-USER_YMIN:<str>         Bottom
Floating point
-USER_YMAX:<str>         Top
Floating point
-USER_SIZE:<str>         Cellsize
Floating point
Minimum: 0.000000
-USER_GRID:<str>         Grid
Data Object (optional output)
-GRID_GRID:<str>         Grid
Grid (output)
C:\>saga_cmd io_gdal 1 -GRIDS
-FORMAT 1 -TYPE 0 -FILE
"C:\Users\me\AppData\Local\Temp\sextante\sagainversedistanceweightedafef52b8ebe84495ac957c5155bd7f0a.tif"
error: Grid file could not be opened.
error: input file
[C:\Users\me\AppData\Local\Temp\sextante\sagainversedistanceweightedafef52b8ebe84495ac957c5155bd7f0a.tif.sgrd]
error: empty input list [GRIDS]
Usage: saga_cmd -GRIDS <str> [-FILE <str>] [-FORMAT <str>] [-TYPE <str>]
[-OPTIONS <str>]
-GRIDS:<str>   Grid(s)
Grid list (input)
-FILE:<str>   File
File path
-FORMAT:<str> Format
Choice
Available Choices:
[0] ERDAS JPEG2000 (SDK 3.x)
[1] Flexible Image Transport System
[2] Network Common Data Format
[3] Virtual Raster
[4] GeoTIFF
[5] National Imagery Transmission Format
[6] Erdas Imagine Images (.img)
[7] ELAS
[8] In Memory Raster
[9] MS Windows Device Independent Bitmap
[10] PCIDSK Database File
[11] ILWIS Raster Map
[12] SGI Image File Format 1.0
[13] Leveller heightfield
[14] Terragen heightfield
[15] USGS Astrogeology ISIS cube (Version 2)
[16] ERMapper .ers Labelled
[17] Raster Matrix Format
[18] Idrisi Raster A.1
[19] Intergraph Raster
[20] Golden Software Binary Grid (.grd)
[21] Portable Pixmap Format (netpbm)
[22] ENVI .hdr Labelled
[23] ESRI .hdr Labelled
[24] PCI .aux Labelled
[25] Vexcel MFF Raster
[26] Vexcel MFF2 (HKV) Raster
[27] VTP .bt (Binary Terrain) 1.3 Format
[28] Erdas .LAN/.GIS
[29] Image Data and Analysis
[30] NOAA Vertical Datum .GTX
[31] NTv2 Datum Grid Shift
[32] ARC Digitized Raster Graphics
[33] SAGA GIS Binary Grid (.sdat)
-TYPE:<str>   Data Type
Choice
Available Choices:
[0] match input data
[1] 8 bit unsigned integer
[2] 16 bit unsigned integer
[3] 16 bit signed integer
[4] 32 bit unsigned integer
[5] 32 bit signed integer
[6] 32 bit floating point
[7] 64 bit floating point
-OPTIONS:<str> Creation Options
Text
C:\>exit
and
SAGA execution commands
io_gdal 1 -GRIDS
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130420/60d0f788/attachment.html>
