[Qgis-user] Vertex markers and Snapping
AntonioLocandro antoniolocandro at hotmail.com
Mon Apr 22 22:22:29 PDT 2013
I was afraid that would be the case, I wanted map units to work not pixels. Thanks anyway
Sent from Samsung tablet"Andreas Neumann [via OSGeo.org]" <ml-node+s1560n5048860h0 at n6.nabble.com> wrote:yes - just look at the digitizing settings in the general options.
However, you cannot set size in map units (zoomable), only in pixels -
they stay the same size, regardless of the zoom factor. So this only
works if you set your snap settings to pixels.
Andreas
Am 22.04.2013 18:12, schrieb AntonioLocandro:
> Hi everyone
> Anybody know if it is possible to set the Vertex Marker Size to match the
> snapping tolerance set for the layer in Snapping options.
> I would like to see the vertex marker size (a circle in my case) that
> represents the tolerance
> Regards,
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Vertex-markers-and-Snapping-tp5048838.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
> [hidden email]
the
[hidden email]
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Vertex-markers-and-Snapping-tp5048838p5048860.html
To unsubscribe from Vertex markers and Snapping, click here.
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Vertex-markers-and-Snapping-tp5048838p5048926.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130422/ce0da568/attachment.html>
