[Qgis-user] Hillshade problem
Carlos Cerdán
sig.upagu at gmail.com
Tue Apr 23 06:01:49 PDT 2013
If you are using a Lat-long DEM perhaps you forgot set the vertical and
horizontal units relation. Its usual to set it to 111120 (1° = 111120 m).
Good luck
Carlos
2013/4/23 Lester Anderson <arctica1963 at gmail.com>
> Hello,
> I have been trying to use the hillsahde option with some raster data, but
> I have not managed to get a good result. The azimuth and angle can be
> changed and that works fine, but the vertical exaggeration does not change
> - tried values from 0.25 to 10, and all look identical ie grossly
> over-exaggerated. Not sure what I am doing wrong?
> Any solutions would be appreciated. I am using v1.8.0 of QGIS.
> Lester
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130423/87d16a50/attachment.html>
