[Qgis-user] Raster color table
Eugenio Trumpy
frippe12573 at hotmail.com
Tue Apr 23 08:54:45 PDT 2013
Hello,I'm using a compiled qgis version 1a91841 in ubuntu 12.10,I would like to color a raster map by using a logarithmic colorinterpolation (logarithmic scaling).I installed the 1-band raster color table plugin, but I got this error message:
An error has occured while executing Python code:
File "/home/eugenio/.qgis2/python/plugins/bcccoltbl1/bcctbl.py", line 1056, in cdlgTBLcr
(lDum, b) = theLayer.noDataValue()
AttributeError: 'QgsRasterLayer' object has no attribute 'noDataValue'
Python version:
2.7.3 (default, Sep 26 2012, 21:53:55)
[GCC 4.7.2]
QGIS version:
1.9.0-Master Master, 1a91841
Python path: ['/usr/local/share/qgis/python/plugins/sextante', '/usr/local/share/qgis/python', '/home/eugenio/.qgis2/python', '/home/eugenio/.qgis2/python/plugins', '/usr/local/share/qgis/python/plugins', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PIL', '/usr/lib/python2.7/dist-packages/gst-0.10', '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7', '/usr/lib/python2.7/dist-packages/ubuntu-sso-client', '/usr/lib/python2.7/dist-packages/ubuntuone-client', '/usr/lib/python2.7/dist-packages/ubuntuone-control-panel', '/usr/lib/python2.7/dist-packages/ubuntuone-couch', '/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol', '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode', '/home/eugenio/.qgis2/python/plugins/mmqgis/forms', '/usr/local/share/qgis/python/plugins/fTools/tools', '/home/eugenio/data_dir/test_procedure', '/usr/share/qgis/python']
What is the problem?Can I use another way?
Regards
Eugenio
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130423/24189e9a/attachment.html>
