[Qgis-user] Where to get a current build without using OSGeo4W
Nathan Woodrow madmanwoo at gmail.com
Thu Apr 25 07:20:02 PDT 2013
Hi Jonathan,
Have you tried using the Use IE settings option. I found this used to work
for me when I was behind a proxy.
Other then that you can download all the OSGeo4w packages on a machine not
behind a proxy using the Download Only option in the installer and then do
a local install using the installer on the machine behind the proxy.
Regards,
Nathan
On Fri, Apr 26, 2013 at 12:09 AM, Jonathan Moules <
jonathanmoules at warwickshire.gov.uk> wrote:
> Hi List,
>   Can anyone advise me where I can get a recent build of QGIS dev/nightly
> for Windows that includes the oracle native components.
> The OSGeo4W installer does not work for me - our proxy server blocks some
> components. As such a single stand alone build is what I'm after.
> Thanks
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130426/def65f70/attachment.html>
