[Qgis-user] Where to get a current build without using OSGeo4W
Nathan Woodrow madmanwoo at gmail.com
Mon Apr 29 03:54:00 PDT 2013
Jonathan,
Have you tried a local install from just packages?
- Nathan
On Mon, Apr 29, 2013 at 8:44 PM, Jonathan Moules <
jonathanmoules at warwickshire.gov.uk> wrote:
> That's pretty much exactly what happens for me too. When I try and go to
> the given URL in a web-browser I get a WebSense error telling me I'm a bad
> person for trying to do "proxy avoidance".
> On 29 April 2013 10:53, skampus <stefano.campus at regione.piemonte.it>wrote:
>> i don't know what happens, but when i try to make a new qgis installation
>> via
>> osgeo4w, sometimes i observe this strange behaviour.
>> all packages are well downloaded except for curl. the proper folder is
>> created in the installation directory but it's not possible to download
>> the
>> package.
>> in this case, i copy from another installation the curl package and in the
>> new pc i make an off line installation.
>> i tought that this could be as "false positive" of our web filter, i don't
>> know...
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Where-to-get-a-current-build-without-using-OSGeo4W-tp5049639p5050176.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> __ _________________________ ____________________
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130429/ddbe9a6a/attachment.html>
