[Qgis-user] Where to get a current build without using OSGeo4W
skampus stefano.campus at regione.piemonte.it
Mon Apr 29 04:42:18 PDT 2013
Jürgen E. Fischer wrote
> It would still miss the curl package (gdal dependency).   But if copying a
> downloaded curl package into the local package directory should help - if
> you
> manage to download by different means.
> Jürgen
hi jurgen, when this problem occurs, i do as you said.
all packages needed for setup are downloaded but installation doesn't end
properly because it misses curl package.
so i copy manually curl package from another installation into the right
directory (for example
C:\OSGeo4W\Setup\http%3a%2f%2fdownload.osgeo.org%2fosgeo4w\release\curl) and
i launch "install from local directory".
and so it goes...
View this message in context: http://osgeo-org.1560.x6.nabble.com/Where-to-get-a-current-build-without-using-OSGeo4W-tp5049639p5050199.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
