[Qgis-user] Where to get a current build without using OSGeo4W
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Tue Apr 30 01:55:00 PDT 2013
Hi Jürgen,
Yep, that downloads just fine!
I wasn't aware of those builds. Just what I was looking for.
Thanks!
Jonathan
On 29 April 2013 17:28, Jürgen E. <jef at norbit.de> wrote:
> Hi Jonathan,
> On Mon, 29. Apr 2013 at 13:56:28 +0100, Jonathan Moules wrote:
> > Nope. As pointed out earlier I have no problem downloading the
> > stand-alones. WebSense only looks at URL's as best I can tell. It doesn't
> > know what the contents of files are. As such, stand-alone builds work
> > fine.
> So no complaints if you try
> http://qgis.org/downloads/weekly/QGIS-OSGeo4W-1.9.0-17-Setup.exe ?
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden
> http://www.norbit.de
> committ(ed|ing) to Quantum GIS                         IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> ________________________
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130430/102cd646/attachment.html>
