[Qgis-user] Running v.clean on a QGIS vector layer (Polygon) through Sextante
Victor Olaya
volayaf at gmail.com
Tue Apr 30 04:24:02 PDT 2013
>> Since GRASS applies som cleaning, at least when importing Polygons, is there
>> a possibility to adjust the cleaning procedure from v.in.ogr there?
> Not advisable: the user must know if it is going to snap or remove small areas.
Click on "show advanced paramters", and you will have two new
parameters to adjust that. They are hidden by default. As Paolo said,
the user should know about that, so they have to be set explicitly,
but they are hidden, since this is advanced stuff.
Thanks!
