[Qgis-user] Running v.clean on a QGIS vector layer (Polygon) through Sextante
SBL
Stefan.Blumentrath at nina.no
Tue Apr 30 04:46:17 PDT 2013
Hi Paolo
Thanks for the swift reply!
Sounds sounds really good.
What I did not understand completely was: Do you mean that the default
settings of v.in.ogr are being used (snapping disabled and min_area set to
0.0001) or is the topology cleaning completely disabled in the v.in.ogr-part
of Sextante?
The cleaning of v.in.ogr can be enough in many cases, I might guess. While
building a propper chain of v.clean steps (with functionallity comparable to
cleaning in v.in.ogr) is a bit more challanging, especially for people
without experience in GRASS...
So maybe importing and exporting to and from GRASS could be used to perform
a quick, simple and beginner-friendly "lightweight-cleaning"?
I see this also as a solution for Bug #2921
<http://hub.qgis.org/issues/2921> , which furthermore offers additional
quality checks...
Actually, before I learned about the possibility in Sextante I considered
creating a plugin for that...
Cheers
Stefan
View this message in context: http://osgeo-org.1560.x6.nabble.com/Running-v-clean-on-a-QGIS-vector-layer-Polygon-through-Sextante-tp5050418p5050427.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
