[Qgis-user] calculate movements along line
Carlos Cerdán
sig.upagu at gmail.com
Tue Apr 30 17:24:55 PDT 2013
Hi Jens:
Not a totally GIS advice, but in this case I use AutoCAD (I think
BricsCAD works also): there is a command to do what you want trough a
line: measure.
Measure puts a block trough a line, every X units.
After that, you can export to DXF format and import to QGIS.
Good luck!
Carlos Cerdán
El 25/04/13 03:47, watercress at gmx.de escribió:
> Hi all,
> I am working with relocations from a telemetry study. I want to
> calculate the movement in meter over time along a physical boundary.
> There a some methods to calculate the distance between points along a
> line but since there are different individuals and the movement
> distance has to be correctly calculated by time this does not seem to
> work for me.
> The point-shape with 500 relocations of 30 individuals looks
> something like this:
> ind, date
> 1,2012-08-05
> 1,2012-09-07
> 1,2012-10-15
> 2,2012-08-05
> I was thinking of creating a line-shape with a given chainage
> (splitted every x meters?)
> perform a buffer and finally an intersect with the point-shape. But
> 1.
> how can I create a line-shape that is splitted every 10 meters..
> 2.
> and how to write the chainage into the table
> chainage
> 1.540
> 1.200
> 0.450
> 1.800
> The resulting point-shape should look likes this:
> ind, date, chainage
> 1,2012-08-05, 1.540
> 1,2012-09-07, 1.200
> 1,2012-10-15, 0.450
> 2,2012-08-05, 1.800
> my approach seems to be a bit antiquated and clumsy
> but I am capable of learning. Any suggestions or any mistake made by me?
> Thanks,
> Jens
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130430/f8a8e055/attachment.html>
