[Qgis-user] Large raster datasets in 2.0
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Tue Aug 20 04:35:29 PDT 2013
I don't think so. The issue is a GDAL one -
http://trac.osgeo.org/gdal/ticket/5067
On 20 August 2013 12:29, Stott James <fmrojst at fylkesmannen.no> wrote:
> Does this bug that has just been fixed solve any of your problems?****
> http://hub.qgis.org/issues/8356****
> I have lots of vrt files with overviews built, and they were taking
> forever to load in QGIS master. Now they open quickly again like in 1.8.**
> *Fra:* qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org] *På vegne av* Jonathan Moules
> *Sendt:* 20. august 2013 13:10
> *Til:* qgis-user at lists.osgeo.org
> *Emne:* [Qgis-user] Large raster datasets in 2.0****
> Hi list, ****
> We have some large raster datasets that are mosaiced into a single
> product. QGIS 1.7 (and I think 1.8) could access these in JP2 or ECW, but
> 2.0 doesn't seem to be able to (or maybe that's a limitation of the
> weeklies and the final thing will be compiled with it?).****
> Due to the size of the rasters combined with a bug in GDAL that causes it
> to take literally a month to process the overviews for super-large rasters
> (about 450,000 * 440,000), we can't create them as a GeoTIFF.****
> So the question - how do I use super-large rasters as a single contiguous
> dataset in QGIS 2?****
> Thanks,****
> Jonathan****
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.****
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130820/5b7d0096/attachment.html>
