[Qgis-user] Four band raster displaying funny
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Mon Dec 2 08:30:15 PST 2013
Hi Andy,
I guess that makes sense.
Relating to gdalwarp:
- Output files by default are larger than gdal_merge.
- But they can be much smaller. You have to set *both*  -wm and --config
GDAL_CACHEMAX - if you only set -wm, then the file is actually larger!
- gdal_merge seems to do something that results in some heavy blurring when
using -co PHOTOMETRIC=YCBCR - this doesn't happen with gdalwarp.
So the optimal filesize for an aerial photograph is rendered with something
like:
gdalwarp -of GTiff -wm 9999 --config GDAL_CACHEMAX 9999 -co TILED=YES -co
> BIGTIFF=YES -co COMPRESS=JPEG -co JPEG_QUALITY=80 -co BLOCKXSIZE=512 -co
> BLOCKYSIZE=512 -co PHOTOMETRIC=YCBCR input1.tif input2.tif output.tif
I've not tried the four-band stuff again; just trying to optimise by 3-band.
Thanks,
Jonathan
On 2 December 2013 16:10, Andrew Harfoot <ajph at geodata.soton.ac.uk> wrote:
>  I think QGIS is innocent in this - if a band is set as an alpha channel
> then it should be handled as such by default in a viewer (so mark down Arc
> for not using the alpha information!).
> GDAL is the culprit as it is adding the alpha interpretation without being
> prompted. I have just replicated this with some RGBI imagery myself: prior
> to passing through GDAL's hands the IR band is present, but isn't
> interpreted as an alpha channel. I can't get the -setci switch to do
> anything though :(
> Cheers,
> Andy
> On 02/12/2013 16:00, Jonathan Moules wrote:
> Hi Andy,
> Yep, that was it. I didn't know QGIS could do that; another good example
> of software trying to be "smart" and confusing the poor user. :-)
>  I didn't know gdalwarp could do mosaicing too. I'll have to test it.
> I'll ask on the gdal list if I want to try the -setci parameter.
>  Many thanks!
> Jonathan
> On 2 December 2013 15:48, Andrew Harfoot <ajph at geodata.soton.ac.uk> wrote:
>>  PS. gdalwarp offers more flexibility when mosaicing rasters, and is
>> better at memory management. I have just noticed that in GDAL 1.10 and
>> above there is an gdalwarp option -setci that 'Sets the color
>> interpretation of the bands of the target dataset from the source dataset'.
>> This could be used to remove the assignment of the alpha channel to the IR
>> band on merging. Sadly there isn't an example of its usage!
>> Cheers,
>> Andy
>> On 02/12/2013 11:53, Jonathan Moules wrote:
>>  Hi List,
>> I've got a 4 band raster aerial photography (RGBI) that comprises lots of
>> tiles. I've merged some of the tiles together with:
>>  gdal_merge -o 1.tif -of GTiff -co TILED=YES -co BIGTIFF=YES -co
>>> COMPRESS=JPEG -co JPEG_QUALITY=50 -co BLOCKXSIZE=512 -co BLOCKYSIZE=512
>>> --optfile tiff_list.txt
>>  But the resultant file looks funny in QGIS.
>> This is what the source file looks like (correct):
>> [image: Inline images 1]
>>  This is what the merged file looks like (wrong):
>> [image: Inline images 2]
>>  All the shadows are a whitey colour. This doesn't happen with 3-band
>> (RGB) images.
>> I've tried comparing individual bands; they all look different in the
>> 4-band.
>>  However, if I open the four-band in ArcGIS, it looks fine (both source
>> and original).
>>  Anyone know what's going on? Is it a QGIS bug or is it doing something
>> "smart"; I can't see anything odd going on with symbology.
>>  Thanks,
>> Jonathan
>>  This transmission is intended for the named addressee(s) only and may
>> contain sensitive or protectively marked material up to RESTRICTED and
>> should be handled accordingly. Unless you are the named addressee (or
>> authorised to receive it for the addressee) you may not copy or use it, or
>> disclose it to anyone else. If you have received this transmission in error
>> please notify the sender immediately. All email traffic sent to or from us,
>> including without limitation all GCSX traffic, may be subject to recording
>> and/or monitoring in accordance with relevant legislation.
>> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
>> Andy Harfoot
>> GeoData Institute
>> University of Southampton
>> Southampton
>> SO17 1BJ
>> Tel:  +44 (0)23 8059 2719
>> Fax:  +44 (0)23 8059 2849
>> www.geodata.soton.ac.uk
> Andy Harfoot
> GeoData Institute
> Southampton
> SO17 1BJ
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131202/1596cb7d/attachment.html>
