[Qgis-user] How load Postgis layer from command line?
Uggla Henrik Henrik.Uggla at kristianstad.se
Thu Dec 5 02:33:53 PST 2013
Is there no documentation about this? The extension mentioned is Postgis itself, not a specific Qgis extension, right?
/Uggla
________________________________________
Skickat: den 28 november 2013 11:29
Till: qgis-user at lists.osgeo.org
Ämne: [Qgis-user] How load Postgis layer from command line?
The command line documentation says:
    Files specified on the command line can include rasters,
    vectors, and QGIS project files (.qgs):
     1. Rasters - supported formats include GeoTiff, DEM
        and others supported by GDAL
     2. Vectors - supported formats include ESRI Shapefiles
        and others supported by OGR and PostgreSQL layers using
        the PostGIS extension
But what's the actual syntax to open a Postgis layer from the command line (should I give connection name, schema, table, username, password etc)?
regards
/Uggla
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
