[Qgis-user] Problems with svg symbols on qgis server
Andreas Neumann a.neumann at carto.net
Mon Dec 9 13:26:16 PST 2013
On what operating system are you and what version are you using?
It seems to be a path-issue and not an X-Server issue. If it was an
X-Server issue your QGIS server would just crash - but it looks like
your maps are drawn, but without SVG symbols. Did you try to copy the
SVG symbols to a path where the standard SVG symbols are located? E.g.
/usr/local/share/qgis/svg on Linux?
Regarding XServer: I use the package "vnc4server" on my Ubuntu Server
along with a small start-script I got from Jürgen. Let me know if you
need this.
Andreas
Am 09.12.2013 21:11, schrieb Leknín Řepánek:
> Good evening
> I have a problem with using svg polygon fill on qgis server. My polygons
> aren`t filled. I tried absolute path (in my desktop solution I`m
> changing svg symbol using table variable). Relative path to qgis project
> location and original qgis svg location. Nothing isn`t working for me. I
> found in older posts on this list, i need running xserver on server with
> qgis server (so much servers :D), but it is old post and I don`t know,
> if I actually need this on this new version.
> Our server works on gentoo.
> Thanks Je;
> Qgis-user mailing list
