[Qgis-user] Wrong WMS extent in QGIS
Jan Hartmann
j.l.h.hartmann at uva.nl
Tue Dec 10 06:04:16 PST 2013
It could have something to to with the WGS84 transformation. QGIS seems
to reproject the coordinates from EPSG:28992 to EPSG:4326. Perhaps it
uses the older transformation from the PROJ library without the seven
-towgs84 parameters. That could explain the difference of about one
hundred meters. Can anyone point out where QGIS stores its
transformation parameters used for the WMS reprojection?
Jan
On 10-12-2013 13:32, Jan Hartmann wrote:
> Has anyone seen this problem? When I do a GetCapabilities request on a
> file I get the following bounding box:
> <BoundingBoxSRS="EPSG:28992"minx="232722"miny="581202"maxx="234016"maxy="582654"/>
> When I load that same file in QGIS, I see in its properties:
> Layer Extent (layer original source projection):
> 232581.2194760067213792,581054.4125426821410656
> 234079.8907057005562820,582558.2655977346003056
> Wrong of course. And QGIS
> cuts the file to the extent it thinks it has, not the real
> extent.
> Jan
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131210/7f70d4c6/attachment.html>
