[Qgis-user] Unable to load PROJ.4 library (libproj.dylib)
William Kyngesburye woklist at kyngchaos.com
Fri Feb 1 07:17:27 PST 2013
This is coming from GDAL, which is odd because I build it with a static PROJ link (to avoid just this problem).  Are you sure you don't have another GDAL library that was used when you compiled QGIS?  maybe from Homebrew or MacPorts?
On Feb 1, 2013, at 2:52 AM, Marcel Stadelmann wrote:
> Hi,
> When I use gdalwarp, I got the following error:
> ERROR 6: Unable to load PROJ.4 library (libproj.dylib), creation of OGRCoordinateTransformation failed.
> After including the following line in .bash_profile, gdalwarp works in the Terminal, but still fails in QGIS when I use the Clipper:
> export PROJSO=/Library/Frameworks/PROJ.framework/PROJ
> I use a Mac OS X 10.8.2 and installed KyngChaos GDAL 1.9 Complete Package and I use QGIS 1.9.0 alpha
> Is there a way to fix that manually or do I have to configure-make-make install again?
> Thanks,
> Marcel
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
