[Qgis-user] Newbie with request for advice
Art alf1361 at zoho.com
Tue Jan 1 12:05:15 PST 2013
I have two options right now. I am a Linux lover, and I am investigating
compiling the Esri File Geodatabase API on Linux. However, the other
option is to handle it all through Windows, probably using OsGeo4Win.
That means I would probably have to make a switch to Windows. I do have
a copy of ESRI's ArcGIS that will work until August that was given to me
for a GIS Course, so I will have that option for some time but it will
not be permanent. Does anyone have a recommended course of action? I
have attached the results from my last compile attempt involving the
File Geodatabase API. I have not found a detailed set of compiling
instructions to make and install it, and am uncertain as to how I should
proceed further.
Art
make -C Domains
make[1]: Entering directory `/home/art/Downloads/FileGDB_API/samples/Domains'
g++ -fPIC -O3 -m64 -W -fexceptions -D_CONSOLE -DUNICODE -D_UNICODE -DUNIX -D_REENTRANT -DFILEGDB_API -D__USE_FILE_OFFSET64 -DUNIX_FILEGDB_API -D_FILE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE -I../../include -I. -m64 -L"../../lib" -o ../bin/Domains ./Domains.o -lFileGDBAPI
/usr/bin/ld: warning: libfgdbunixrtl.so, needed by ../../lib/libFileGDBAPI.so, not found (try using -rpath or -rpath-link)
../../lib/libFileGDBAPI.so: undefined reference to `SysAllocStringByteLen(char*, unsigned int)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IGeometry'
../../lib/libFileGDBAPI.so: undefined reference to `WideCharToMultiByte(unsigned int, unsigned int, wchar_t const*, int, char*, int, char const*, int*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IProjectedCoordinateSystem5'
../../lib/libFileGDBAPI.so: undefined reference to `PathRemoveFileSpecW(wchar_t*)'
../../lib/libFileGDBAPI.so: undefined reference to `VarR8FromDate(double, double*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IEnumSchemaLockInfoImpl'
../../lib/libFileGDBAPI.so: undefined reference to `IsCharAlphaNumeric(wchar_t)'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_RasterValue'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IRasterDef'
../../lib/libFileGDBAPI.so: undefined reference to `IID_ISchemaLock'
../../lib/libFileGDBAPI.so: undefined reference to `GetCommandLineW()'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IEnvelope'
../../lib/libFileGDBAPI.so: undefined reference to `SysFreeString(wchar_t*)'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_Multipoint'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IQueryFilterFIDSet'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_SpatialReferenceEnvironment'
../../lib/libFileGDBAPI.so: undefined reference to `HeapAlloc(void*, unsigned int, unsigned long)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IIndexesEdit'
../../lib/libFileGDBAPI.so: undefined reference to `DebugBreak()'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_MemoryBlobStream'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_Polygon'
../../lib/libFileGDBAPI.so: undefined reference to `LoadStringW(void*, unsigned int, wchar_t*, int)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IPersistStream'
../../lib/libFileGDBAPI.so: undefined reference to `IID_ISchemaLockInfo'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IGeographicCoordinateSystem'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IUnknown'
../../lib/libFileGDBAPI.so: undefined reference to `IID_ISupportErrorInfo'
../../lib/libFileGDBAPI.so: undefined reference to `PathRenameExtension(wchar_t*, wchar_t const*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IESRIShape'
../../lib/libFileGDBAPI.so: undefined reference to `SafeArrayLock(tagSAFEARRAY*)'
../../lib/libFileGDBAPI.so: undefined reference to `GetLocalTime(_SYSTEMTIME*)'
../../lib/libFileGDBAPI.so: undefined reference to `DeleteCriticalSection(CRITICAL_SECTION*)'
../../lib/libFileGDBAPI.so: undefined reference to `LeaveCriticalSection(CRITICAL_SECTION*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IEnumConfigurationParameter'
../../lib/libFileGDBAPI.so: undefined reference to `LoadLibraryEx(wchar_t const*, void*, unsigned int)'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_Index'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IGeometryDefEdit'
../../lib/libFileGDBAPI.so: undefined reference to `HtmlHelpW(HWND__*, wchar_t const*, unsigned int, unsigned long)'
../../lib/libFileGDBAPI.so: undefined reference to `SetThreadUILanguage(unsigned short)'
../../lib/libFileGDBAPI.so: undefined reference to `_tcstok(wchar_t*, wchar_t const*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IGeometry4'
../../lib/libFileGDBAPI.so: undefined reference to `str_utf8_len(char const*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IEnumIndex'
../../lib/libFileGDBAPI.so: undefined reference to `SysAllocString(wchar_t const*)'
../../lib/libFileGDBAPI.so: undefined reference to `CoCreateInstance(_GUID const&, IUnknown*, unsigned int, _GUID const&, void**)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IAngularUnit'
../../lib/libFileGDBAPI.so: undefined reference to `GetUserDefaultUILanguage()'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IRasterValue'
../../lib/libFileGDBAPI.so: undefined reference to `InterlockedDecrement(atomicLong*)'
../../lib/libFileGDBAPI.so: undefined reference to `MultiByteToWideChar(unsigned int, unsigned int, char const*, int, wchar_t*, int)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IIndexEdit'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IWorkspace'
../../lib/libFileGDBAPI.so: undefined reference to `GetCurrentThreadId()'
../../lib/libFileGDBAPI.so: undefined reference to `CoTaskMemAlloc(unsigned long)'
../../lib/libFileGDBAPI.so: undefined reference to `Sleep(unsigned int)'
../../lib/libFileGDBAPI.so: undefined reference to `uuidof(wchar_t*)'
../../lib/libFileGDBAPI.so: undefined reference to `str_uni_to_utf8(char*, wchar_t const*, int)'
../../lib/libFileGDBAPI.so: undefined reference to `VarR8FromStr(wchar_t*, unsigned int, unsigned int, double*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IMemoryBlobStream'
../../lib/libFileGDBAPI.so: undefined reference to `IID_ISpatialReference2'
../../lib/libFileGDBAPI.so: undefined reference to `_wmakepath(wchar_t*, wchar_t const*, wchar_t const*, wchar_t const*, wchar_t const*)'
../../lib/libFileGDBAPI.so: undefined reference to `HeapFree(void*, unsigned int, void*)'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_GeometryDef'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IIndexes'
../../lib/libFileGDBAPI.so: undefined reference to `_wtoi64(wchar_t const*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IProjectedCoordinateSystem2'
../../lib/libFileGDBAPI.so: undefined reference to `wcscpy_s(wchar_t*, unsigned long, wchar_t const*)'
../../lib/libFileGDBAPI.so: undefined reference to `SysStringLen(wchar_t*)'
../../lib/libFileGDBAPI.so: undefined reference to `CoGetClassObject(_GUID const&, unsigned int, _COSERVERINFO*, _GUID const&, void**)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IGeometryDef'
../../lib/libFileGDBAPI.so: undefined reference to `OpenProcess(unsigned int, int, unsigned int)'
../../lib/libFileGDBAPI.so: undefined reference to `_wsetlocale(int, wchar_t const*)'
../../lib/libFileGDBAPI.so: undefined reference to `VariantCopy(tagVARIANT*, tagVARIANT*)'
../../lib/libFileGDBAPI.so: undefined reference to `_vstprintf(wchar_t*, unsigned long, wchar_t const*, __va_list_tag*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IPersist'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IField'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IQueryFilterDefinition2'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_Fields'
../../lib/libFileGDBAPI.so: undefined reference to `GUID_NULL'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IConfigurationParameter2'
../../lib/libFileGDBAPI.so: undefined reference to `_wfullpath(wchar_t*, wchar_t const*, unsigned long)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IFieldsEdit'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_ConfigurationParameter'
../../lib/libFileGDBAPI.so: undefined reference to `IID_ICursor'
../../lib/libFileGDBAPI.so: undefined reference to `VarDateFromR8(double, double*)'
../../lib/libFileGDBAPI.so: undefined reference to `wcsnicmp(wchar_t const*, wchar_t const*, unsigned long)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IFieldEdit2'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IFIDSet'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IModelInfo'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IESRIShape2'
../../lib/libFileGDBAPI.so: undefined reference to `wcscat_s(wchar_t*, unsigned long, wchar_t const*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_ISpatialFilter'
../../lib/libFileGDBAPI.so: undefined reference to `SafeArrayAccessData(tagSAFEARRAY*, void**)'
../../lib/libFileGDBAPI.so: undefined reference to `HRESULT_FROM_WIN32(unsigned int)'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_ProjectedCoordinateSystem'
../../lib/libFileGDBAPI.so: undefined reference to `CoCreateGuid(_GUID*)'
../../lib/libFileGDBAPI.so: undefined reference to `InterlockedIncrement(atomicLong*)'
../../lib/libFileGDBAPI.so: undefined reference to `GetProcAddress(void*, char const*)'
../../lib/libFileGDBAPI.so: undefined reference to `EnterCriticalSection(CRITICAL_SECTION*)'
../../lib/libFileGDBAPI.so: undefined reference to `SafeArrayGetLBound(tagSAFEARRAY*, unsigned int, int*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IConfigurationKeyword'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IGeometry5'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IControlPrecision2'
../../lib/libFileGDBAPI.so: undefined reference to `GetLocaleInfo(unsigned int, unsigned int, wchar_t*, int)'
../../lib/libFileGDBAPI.so: undefined reference to `SetThreadLocale(unsigned int)'
../../lib/libFileGDBAPI.so: undefined reference to `ProgIDFromCLSID(_GUID const&, wchar_t**)'
../../lib/libFileGDBAPI.so: undefined reference to `PathFindFileNameW(wchar_t const*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IQueryFilter'
../../lib/libFileGDBAPI.so: undefined reference to `GetFileAttributes(wchar_t const*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_ISpatialReference'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IRasterDef2'
../../lib/libFileGDBAPI.so: undefined reference to `GetUserDefaultLangID()'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_Envelope'
../../lib/libFileGDBAPI.so: undefined reference to `VarBstrFromR8(double, unsigned int, unsigned int, wchar_t**)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IEnumSchemaLockInfo'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IFields2'
../../lib/libFileGDBAPI.so: undefined reference to `IID_ISpatialReference3'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IProjectedCoordinateSystem3'
../../lib/libFileGDBAPI.so: undefined reference to `wcsncoll(wchar_t const*, wchar_t const*, unsigned long)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IXMLIndexEdit'
../../lib/libFileGDBAPI.so: undefined reference to `GetCurrentProcessId()'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IEnumConfigurationKeyword'
../../lib/libFileGDBAPI.so: undefined reference to `VariantChangeType(tagVARIANT*, tagVARIANT*, unsigned short, unsigned short)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IStream'
../../lib/libFileGDBAPI.so: undefined reference to `CLSIDFromString(wchar_t const*, _GUID*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IClassID'
../../lib/libFileGDBAPI.so: undefined reference to `PathIsDirectory(wchar_t const*)'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_MultiPatch'
../../lib/libFileGDBAPI.so: undefined reference to `SafeArrayUnlock(tagSAFEARRAY*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IErrorRecords'
../../lib/libFileGDBAPI.so: undefined reference to `VariantClear(tagVARIANT*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IControlPrecision'
../../lib/libFileGDBAPI.so: undefined reference to `VariantInit(tagVARIANT*)'
../../lib/libFileGDBAPI.so: undefined reference to `SystemTimeToVariantTime(_SYSTEMTIME*, double*)'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_GeometryEnvironment'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IBlobStream'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IField2'
../../lib/libFileGDBAPI.so: undefined reference to `IID_ISpatialReferenceInfo'
../../lib/libFileGDBAPI.so: undefined reference to `CloseHandle(void*)'
../../lib/libFileGDBAPI.so: undefined reference to `SafeArrayCreate(unsigned short, unsigned int, tagSAFEARRAYBOUND*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IEnumSpatialReferenceInfo'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_ConfigurationKeyword'
../../lib/libFileGDBAPI.so: undefined reference to `GetModuleFileName(void*, wchar_t*, unsigned int)'
../../lib/libFileGDBAPI.so: undefined reference to `OutputDebugString(wchar_t const*)'
../../lib/libFileGDBAPI.so: undefined reference to `HeapReAlloc(void*, unsigned int, void*, unsigned long)'
../../lib/libFileGDBAPI.so: undefined reference to `_fpreset()'
../../lib/libFileGDBAPI.so: undefined reference to `CoTaskMemFree(void*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IGeometryFactory'
../../lib/libFileGDBAPI.so: undefined reference to `SetErrorInfo(unsigned int, IErrorInfo*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IClone'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IUnknownCoordinateSystem'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_UnknownCoordinateSystem'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_FIDSet'
../../lib/libFileGDBAPI.so: undefined reference to `str_utf8_to_uni(wchar_t*, char const*, int)'
../../lib/libFileGDBAPI.so: undefined reference to `GetLongPathName(wchar_t const*, wchar_t*, unsigned int)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IGeographicCoordinateSystem2'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IFIDSet2'
../../lib/libFileGDBAPI.so: undefined reference to `SafeArrayUnaccessData(tagSAFEARRAY*)'
../../lib/libFileGDBAPI.so: undefined reference to `InitializeCriticalSection(CRITICAL_SECTION*)'
../../lib/libFileGDBAPI.so: undefined reference to `InitializeCriticalSectionAndSpinCount(CRITICAL_SECTION*, unsigned int)'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_AngularUnit'
../../lib/libFileGDBAPI.so: undefined reference to `FormatMessage(unsigned int, void const*, unsigned int, unsigned int, wchar_t*, unsigned int, __va_list_tag (*) [1])'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IEnumIDs'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IGeometry2'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_Polyline'
../../lib/libFileGDBAPI.so: undefined reference to `SysAllocStringLen(wchar_t const*, unsigned int)'
../../lib/libFileGDBAPI.so: undefined reference to `FindFirstFile(wchar_t const*, _WIN32_FIND_DATA*)'
../../lib/libFileGDBAPI.so: undefined reference to `LocalFree(void*)'
../../lib/libFileGDBAPI.so: undefined reference to `VarBstrFromDate(double, unsigned int, unsigned int, wchar_t**)'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_RasterDef'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IRasterDatasetNameEx'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IXMLIndex'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_GeographicCoordinateSystem'
../../lib/libFileGDBAPI.so: undefined reference to `EnumSystemLocales(int (*)(wchar_t*), unsigned int)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IRelationalOperator'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IGeometryDefImpl'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IProjectedCoordinateSystem4'
../../lib/libFileGDBAPI.so: undefined reference to `VariantTimeToSystemTime(double, _SYSTEMTIME*)'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_XMLIndex'
../../lib/libFileGDBAPI.so: undefined reference to `SysStringByteLen(wchar_t*)'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_Point'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IConfigurationParameter'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_Indexes'
../../lib/libFileGDBAPI.so: undefined reference to `WinHelpW(HWND__*, wchar_t const*, unsigned int, unsigned long)'
../../lib/libFileGDBAPI.so: undefined reference to `GetEnvironmentVariable(wchar_t const*, wchar_t*, unsigned int)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IFIDSetOperator'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IErrorInfo'
../../lib/libFileGDBAPI.so: undefined reference to `IID_ISpatialReferenceFactory'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IFieldImpl'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IClassFactory'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IESRISpatialReferenceGEN'
../../lib/libFileGDBAPI.so: undefined reference to `_wcsinc(wchar_t const*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_ICompareCoordinateSystems'
../../lib/libFileGDBAPI.so: undefined reference to `swscanf_s(wchar_t const*, wchar_t const*, ...)'
../../lib/libFileGDBAPI.so: undefined reference to `PathIsDirectoryW(wchar_t const*)'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_ESRIExtendedErrorInfo'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IFieldEdit'
../../lib/libFileGDBAPI.so: undefined reference to `VariantChangeTypeEx(tagVARIANT*, tagVARIANT*, unsigned int, unsigned short, unsigned short)'
../../lib/libFileGDBAPI.so: undefined reference to `GetComputerName(wchar_t*, unsigned int*)'
../../lib/libFileGDBAPI.so: undefined reference to `GetErrorInfo(unsigned int, IErrorInfo**)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IFields'
../../lib/libFileGDBAPI.so: undefined reference to `IID_ISequentialStream'
../../lib/libFileGDBAPI.so: undefined reference to `SafeArrayDestroy(tagSAFEARRAY*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IProjectedCoordinateSystem'
../../lib/libFileGDBAPI.so: undefined reference to `PathIsDirectoryEmpty(wchar_t const*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IIndex'
../../lib/libFileGDBAPI.so: undefined reference to `SafeArrayGetUBound(tagSAFEARRAY*, unsigned int, int*)'
../../lib/libFileGDBAPI.so: undefined reference to `VarDateFromStr(wchar_t*, unsigned int, unsigned int, double*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IFieldsInfo'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IConfigurationKeyword2'
../../lib/libFileGDBAPI.so: undefined reference to `StringFromGUID2(_GUID const&, wchar_t*, int)'
../../lib/libFileGDBAPI.so: undefined reference to `PathCombineW(wchar_t*, wchar_t const*, wchar_t const*)'
../../lib/libFileGDBAPI.so: undefined reference to `GetProcessHeap()'
../../lib/libFileGDBAPI.so: undefined reference to `GetModuleHandle(wchar_t const*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_ISpatialReferenceTolerance'
../../lib/libFileGDBAPI.so: undefined reference to `_wsplitpath(wchar_t const*, wchar_t*, wchar_t*, wchar_t*, wchar_t*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IGeometry3'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IUnit'
../../lib/libFileGDBAPI.so: undefined reference to `_wcsnicoll(wchar_t const*, wchar_t const*, unsigned long)'
../../lib/libFileGDBAPI.so: undefined reference to `FindClose(void*)'
../../lib/libFileGDBAPI.so: undefined reference to `CreateErrorInfo(ICreateErrorInfo**)'
../../lib/libFileGDBAPI.so: undefined reference to `StringFromCLSID(_GUID const&, wchar_t**)'
../../lib/libFileGDBAPI.so: undefined reference to `str_uni_bytes(wchar_t const*)'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IMemoryBlobStream2'
../../lib/libFileGDBAPI.so: undefined reference to `IID_IEnvelope2'
../../lib/libFileGDBAPI.so: undefined reference to `LoadLibrary(wchar_t const*)'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_Field'
../../lib/libFileGDBAPI.so: undefined reference to `CommandLineToArgvW(wchar_t const*, int*)'
../../lib/libFileGDBAPI.so: undefined reference to `FindNextFile(void*, _WIN32_FIND_DATA*)'
../../lib/libFileGDBAPI.so: undefined reference to `PathFileExistsW(wchar_t const*)'
../../lib/libFileGDBAPI.so: undefined reference to `PathFindExtensionW(wchar_t const*)'
collect2: error: ld returned 1 exit status
make[1]: *** [../bin/Domains] Error 1
make[1]: Leaving directory `/home/art/Downloads/FileGDB_API/samples/Domains'
make: *** [Domains] Error 2
