[Qgis-user] Problem downloading exercise data
Oluwole Morenikeji
wolekeji at yahoo.com
Sat Jan 5 01:54:13 PST 2013
What I found at the referenced data site could not be downloaded to work with in the training manual
https://github.com/qgis/QGIS-Training-Manual/tree/master/exercise_data
From: "qgis-user-request at lists.osgeo.org" <qgis-user-request at lists.osgeo.org>
To: qgis-user at lists.osgeo.org
Sent: Friday, January 4, 2013 9:00 PM
Subject: Qgis-user Digest, Vol 83, Issue 8
Send Qgis-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Qgis-user digest..."
Today's Topics:
1. Re: Could not find exercise data (Andre Joost)
2. Re: Newbie with request for advice (Art)
Message: 1
Date: Fri, 04 Jan 2013 16:30:48 +0100
Subject: Re: [Qgis-user] Could not find exercise data
Message-ID: <kc6sjg$e2l$1 at ger.gmane.org>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Am 04.01.2013 15:09, schrieb Oluwole Morenikeji:
> I installed
> Qgis 1.8 and its latest training manual release. I also downloaded qgis sample
> data but following the training manual the data used for the training is not
> found in the sample data folder e.g. I was frustrated following this
> instruction
> Click on the Browse button and navigate to the file
> exercise_data/streets.shp
> (in your course directory). What I found in the directory is Alaska folder.
> What do I do please.
I guess you are looking for this data:
I wish someone could put a link on the page where the training manual is...
HTH,
Andr? Joost
Message: 2
Date: Fri, 04 Jan 2013 13:49:10 -0600
To: qgis-user <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Newbie with request for advice
Message-ID: <50E73236.7070400 at zoho.com>
Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
Yes! Any information on implementing this feature on Linux would be much
appreciated.
Art
On 1/4/2013 8:08 AM, Johan Nilsson wrote:
> I'm also very interested in 'ESRI file geodatabase', not the 'Personal
> geodatabase', ( mdb or ms-access, or JET database) that ESRI not
> recommend to use...
> I tried to compile for month ago, but I think I stuck on the same
> place Art get stuck..
> /Cheers
> 2013/1/4 Randal Hale <rjhale at northrivergeographic.com
> <mailto:rjhale at northrivergeographic.com>>
> Hi Art,
> So I've got QGIS running on windows and linux. I haven't tried to
> compile file geodatabase support into my linux install (that's on
> my list to do). On my windows install I'm running OSGeo4Win -
> adding file based geodatabase support was easy - I just added the
> "module" and had support (I'm currently on my linux machine and
> not near my windows machine - or I would tell you exactly what I
> added).
> My windows machine is running Windows 7 64bit - my linux machine
> is running xubuntu. I own a consulting business and have ArcGIS
> running on my windows machine. There's not way I'm ever going to
> windows 8. So I'm sticking with windows 7 for ESRI and migrating
> as much of my workflow over to linux as I can...as I tell people -
> A clip is a clip and a buffer is a buffer. So I'll do what I can
> on linux and when I have to go with ESRI I'll jump over to windows.
> Now that I read all of this - I should really try to compile file
> based support on this laptop over the weekend.
> Randy
> Randal Hale, GISP
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611 <tel:423.653.3611> rjhale at northrivergeographic.com <mailto:rjhale at northrivergeographic.com>
> twitter:rjhale
> http://about.me/rjhale
> On 01/01/2013 03:05 PM, Art wrote:
>> I have two options right now. I am a Linux lover, and I am
>> investigating compiling the Esri File Geodatabase API on Linux.
>> However, the other option is to handle it all through Windows,
>> probably using OsGeo4Win. That means I would probably have to
>> make a switch to Windows. I do have a copy of ESRI's ArcGIS that
>> will work until August that was given to me for a GIS Course, so
>> I will have that option for some time but it will not be
>> permanent. Does anyone have a recommended course of action? I
>> have attached the results from my last compile attempt involving
>> the File Geodatabase API. I have not found a detailed set of
>> compiling instructions to make and install it, and am uncertain
>> as to how I should proceed further.
>> Art
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130104/f4228057/attachment-0001.html>
End of Qgis-user Digest, Vol 83, Issue 8
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130105/f1e84ad4/attachment.html>
