[Qgis-user] Sextante modeller input settings
Victor Olaya volayaf at gmail.com
Fri Jan 11 08:08:52 PST 2013
You mean that when you add an input to the modeler and later edit that
input, you do not see the previous config values for it? That is
because that behaviour is not yet implemented, it opens back with
fresh config values, instead of the ones you set the last time you
edited the parameter. It is on my todo list...and maybe will try do
work on it this weekend. Not a difficult thing, but it is not a very
exciting task, so I have been procrastinating... ;.)
2013/1/11 Michał Bełcik <belcikmichal at gmail.com>:
> Hi everyone
> I do not know if anyone experienced the same problem with Sextante modeler,
> but it does not remember the settings of the input. For example, whenever I
> create a model and I want to limit certain Vector layer type to points only,
> or specify the layer table from which the certain field should be read,
> after clicking the "Edit" button settings are automatically set to default
> once again. Saving the model etc does not help. When running the model,
> there are also "default" options available. Does anyone know what to do with
> that problem?
> Best regards
> Michal
> Qgis-user mailing list
