[Qgis-user] QGIS Master
Andreas Neumann a.neumann at carto.net
Wed Jan 23 10:14:20 PST 2013
Hi Jonathan,
This is often a problem of the proxy server. One thing you could do is
download the file manually with wget --no-proxy option. This would force
the proxy to load the file again instead of serving you an older,
potentially corrupted version.
You can directly download the problematic package from
http://download.osgeo.org/osgeo4w/release/
Hope this helps?
Andreas
Am 23.01.2013 18:16, schrieb Jonathan Moules:
> Seems like I spoke too soon.
> At about the 200MB mark I get an error pop up:
> "Download Incomcplete. Try again?"
> Pressing yes takes me back to the previous page. I click "next" agan and
> just get the error again. I've tried this over the last couple of hours.
> I deleted all the downloaded packages but restarting was to no avail.
> The package its stuck on is curl-7.15.1-2.tar.bz2
> Anyone else get this?
> Jonathan
> On 23 January 2013 14:37, Jonathan Moules <
> jonathanmoules at warwickshire.gov.uk> wrote:
>> Somehow I missed that option. Thanks both, that worked.
>> Jonathan
>> On 23 January 2013 13:29, Andreas Neumann <a.neumann at carto.net> wrote:
>>> Hi,
>>> Yes, the "Use IE settings" options works for me as well. Please try that
>>> first before looking for alternatives.
>>> Andreas
>>> On Wed, 23 Jan 2013 23:14:21 +1000, Nathan Woodrow wrote:
>>>> Jonathan,
>>>> I have you tried the "Use IE Settings" option.  I'm behind a firewall
>>>> at work and that seems to work for me.
>>>> - Nathan
>>>> On Wed, Jan 23, 2013 at 10:55 PM, Jonathan Moules  wrote:
>>>>  Hi List,
>>>>> I'm trying to get QGIS Master for Windows to test some of my bugs.
>>>>> I'm sitting behind a corporate Proxy that requires a
>>>>> username/password.
>>>>> The OSGeo4W Installer has a proxy option but can't handle our proxy
>>>>> it seems so just stalls.
>>>>> There is an option for installing from pre-downloaded files. Where
>>>>> can I get those files from without using the OSGeo4W installer?
>>>>> Cheers,
>>>>> Jonathan
>>>>> This transmission is intended for the named addressee(s) only and
>>>>> may contain sensitive or protectively marked material up to
>>>>> RESTRICTED and should be handled accordingly. Unless you are the
>>>>> named addressee (or authorised to receive it for the addressee) you
>>>>> may not copy or use it, or disclose it to anyone else. If you have
>>>>> received this transmission in error please notify the sender
>>>>> immediately. All email traffic sent to or from us, including without
>>>>> limitation all GCSX traffic, may be subject to recording and/or
>>>>> monitoring in accordance with relevant legislation.
>>>>> _______________________
> _______**_________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org [1]
>>>>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>[2]
>>>> Links:
>>>> [1] mailto:Qgis-user at lists.osgeo.**org <Qgis-user at lists.osgeo.org>
>>>> [2] http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
>>>> [3] mailto:jonathanmoules@**warwickshire.gov.uk<jonathanmoules at warwickshire.gov.uk>
>>> Andreas Neumann
>>> Böschacherstrasse 10A
>>> 8624 Grüt (Gossau ZH)
>>> Switzerland
>>> ________________________
> This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
