[Qgis-user] GetMap and GetCapabilities problem in QGISserver
Spalting, Hermann (Kreis Lippe)
H.Spalting at kreis-lippe.de
Mon Jan 28 02:47:54 PST 2013
after installing QGISserver the first time, i have it running and qgis_mapserv.fcgi.exe does respond.
When trying a GetMap or GetCapabilities i receive erros. I tested with the holloworld.qgs and my own test.qgs with one pointlayer.
In desktop QGIS everything is fine.
Maybe I have a problem with the srs.db
http://localhost/cgi-bin/qgis_mapserv.fcgi.exe?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&map=C:/OSGeo4W/apache/htdocs/qgis-web-client/projects/test.qgs&FORMAT=image/png&CRS=EPSG:25832&WIDTH=500&HEIGHT=500&LAYERS=WKA
results in
- <ServiceExceptionReport version="1.3.0" xmlns="http://www.opengis.net/ogc">
<ServiceException code="InvalidCRS">Could not create output CRS</ServiceException>
</ServiceExceptionReport>
http://localhost/cgi-bin/qgis_mapserv.fcgi.exe?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities&map=C:/OSGeo4W/apache/htdocs/qgis-web-client/projects/helloworld.qgs
resesposenses with some info but no layerinformation
and this in the error.log:
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgsproviderregistry.cpp(86) : (QgsProviderRegistry::QgsProviderRegistry) Checking C:/OSGeo4W/plugins for provider plugins\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgsmessagelog.cpp(41) : (QgsMessageLog::logMessage) 2013-01-28T11:41:47 No Data Providers[0] No QGIS data provider plugins found in:\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] C:/OSGeo4W/plugins\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] No vector layers can be loaded. Check your QGIS installation\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgis_map_serv.cpp(170) : (main) Prefix PATH: C:/OSGeo4W\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgis_map_serv.cpp(171) : (main) Plugin PATH: C:/OSGeo4W/plugins\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgis_map_serv.cpp(172) : (main) PkgData PATH: C:/OSGeo4W/.\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgis_map_serv.cpp(173) : (main) User DB PATH: C:/WINNT/system32/config/systemprofile/.qgis//qgis.db\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgis_map_serv.cpp(175) : (main) C:/OSGeo4W/bin/qgis_wms_server.log\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgis_map_serv.cpp(117) : (defaultProjectFile) current directory: C:/OSGeo4W/bin\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgscoordinatereferencesystem.cpp(277) : (QgsCoordinateReferenceSystem::loadFromDb) failed : C:/OSGeo4W/./resources/srs.db does not exist!\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgscoordinatetransform.cpp(143) : (QgsCoordinateTransform::initialise) SourceCRS seemed invalid!\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgsmessagelog.cpp(41) : (QgsMessageLog::logMessage) 2013-01-28T11:41:47 [0] Can't open database: unable to open database file\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgsscalecalculator.cpp(42) : (QgsScaleCalculator::setMapUnits) Map units set to 2\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgsscalecalculator.cpp(137) : (QgsScaleCalculator::calculateGeographicDistance) Distance across map extent (m): 0\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgsscalecalculator.cpp(88) : (QgsScaleCalculator::calculate) Using conversionFactor of 39.3701\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgsscalecalculator.cpp(91) : (QgsScaleCalculator::calculate) Can't calculate scale from the input values\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgis_map_serv.cpp(80) : (printRequestInfos) ************************new request**********************\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgis_map_serv.cpp(81) : (printRequestInfos) 2013-01-28 11:41:47\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgis_map_serv.cpp(85) : (printRequestInfos) remote ip: 127.0.0.1\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgis_map_serv.cpp(109) : (printRequestInfos) HTTP_USER_AGENT: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; Trident/4.0; .NET CLR 2.0.50727; .NET CLR 3.0.04506.648; .NET CLR 3.5.21022; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; .NET4.0C)\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgis_map_serv.cpp(217) : (main) Creating QgsGetRequestHandler\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgsgetrequesthandler.cpp(36) : (QgsGetRequestHandler::parseInput) query string is: SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities&map=C:/OSGeo4W/apache/htdocs/qgis-web-client/projects/helloworld.qgs\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgshttprequesthandler.cpp(392) : (QgsHttpRequestHandler::requestStringToParameterMap) inserting pair SERVICE // WMS into the parameter map\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgshttprequesthandler.cpp(392) : (QgsHttpRequestHandler::requestStringToParameterMap) inserting pair VERSION // 1.3.0 into the parameter map\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgshttprequesthandler.cpp(392) : (QgsHttpRequestHandler::requestStringToParameterMap) inserting pair REQUEST // GetCapabilities into the parameter map\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgshttprequesthandler.cpp(392) : (QgsHttpRequestHandler::requestStringToParameterMap) inserting pair MAP // C:/OSGeo4W/apache/htdocs/qgis-web-client/projects/helloworld.qgs into the parameter map\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgsconfigcache.cpp(60) : (QgsConfigCache::searchConfiguration) Create new configuration\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgis_map_serv.cpp(418) : (main) Capabilities document not found in cache\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgswmsserver.cpp(84) : (QgsWMSServer::getCapabilities) Entering.\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgswmsserver.cpp(260) : (QgsWMSServer::getCapabilities) calling layersAndStylesCapabilities\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgsmslayercache.cpp(98) : (QgsMSLayerCache::searchLayer) Layer not found in cache\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgsmaplayer.cpp(53) : (QgsMapLayer::QgsMapLayer) lyrname is ''\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgsmaplayer.cpp(59) : (QgsMapLayer::QgsMapLayer) layerName is ''\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgscoordinatereferencesystem.cpp(1097) : (QgsCoordinateReferenceSystem::readXML) Reading Spatial Ref Sys from xml ------------------------!\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgscoordinatereferencesystem.cpp(448) : (QgsCoordinateReferenceSystem::createFromProj4) proj4: +proj=longlat +datum=WGS84 +no_defs\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgscoordinatereferencesystem.cpp(466) : (QgsCoordinateReferenceSystem::createFromProj4) proj string supplied has no +ellps argument\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgscoordinatereferencesystem.cpp(478) : (QgsCoordinateReferenceSystem::createFromProj4) proj string supplied has no +a argument\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgscoordinatereferencesystem.cpp(663) : (QgsCoordinateReferenceSystem::getRecord) running query: select * from tbl_srs where parameters='+proj=longlat +datum=WGS84 +no_defs' order by deprecated\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgscoordinatereferencesystem.cpp(670) : (QgsCoordinateReferenceSystem::getRecord) failed : C:/OSGeo4W/./resources/srs.db does not exist!\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgscoordinatereferencesystem.cpp(663) : (QgsCoordinateReferenceSystem::getRecord) running query: SELECT * FROM tbl_srs WHERE ' '||parameters||' ' LIKE '% +proj=longlat %' AND ' '||parameters||' ' LIKE '% +no_defs %' AND ' '||parameters||' ' LIKE '% +datum=WGS84 %' order by deprecated\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgscoordinatereferencesystem.cpp(663) : (QgsCoordinateReferenceSystem::getRecord) running query: SELECT * FROM tbl_srs WHERE ' '||parameters||' ' LIKE '% +proj=longlat %' AND ' '||parameters||' ' LIKE '% +no_defs %' order by deprecated\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgscoordinatereferencesystem.cpp(587) : (QgsCoordinateReferenceSystem::createFromProj4) globbing search for srsid from this proj string\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgscoordinatereferencesystem.cpp(963) : (QgsCoordinateReferenceSystem::findMatchingProj) entered.\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgscoordinatereferencesystem.cpp(1331) : (QgsCoordinateReferenceSystem::openDb) Can't open database: unable to open database file\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgsmessagelog.cpp(41) : (QgsMessageLog::logMessage) 2013-01-28T11:41:47 CRS[0] Could not open CRS database C:/OSGeo4W/./resources/srs.db\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] Error(14): unable to open database file\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgscoordinatereferencesystem.cpp(590) : (QgsCoordinateReferenceSystem::createFromProj4) globbing search for srsid returned srsid: 0\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgscoordinatereferencesystem.cpp(604) : (QgsCoordinateReferenceSystem::createFromProj4) Projection is not found in databases.\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgscoordinatereferencesystem.cpp(663) : (QgsCoordinateReferenceSystem::getRecord) running query: select * from tbl_srs where parameters='+proj=longlat +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +no_defs' order by deprecated\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgscoordinatereferencesystem.cpp(615) : (QgsCoordinateReferenceSystem::createFromProj4) Projection appears to be valid. Save to database!\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgscoordinatereferencesystem.cpp(1437) : (QgsCoordinateReferenceSystem::saveAsUserCRS) Update or insert sql \r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] insert into tbl_srs (srs_id,description,projection_acronym,ellipsoid_acronym,parameters,is_geo) values (100000,' * Generated CRS (+proj=longlat +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +no_defs)','longlat','','+proj=longlat +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +no_defs',0)\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgsmessagelog.cpp(41) : (QgsMessageLog::logMessage) 2013-01-28T11:41:47 CRS[0] Saved user CRS [+proj=longlat +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +no_defs]\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgscoordinatereferencesystem.cpp(642) : (QgsCoordinateReferenceSystem::createFromProj4) Couldn't find newly added proj string?\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgscoordinatereferencesystem.cpp(1153) : (QgsCoordinateReferenceSystem::readXML) Setting from elements one by one\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgsvectorlayer.cpp(2722) : (QgsVectorLayer::readXml) Datasource in QgsVectorLayer::readXml: dbname='C:/OSGeo4W/apache/htdocs/qgis-web-client/data/helloworld.db' table="country" (geometry) sql=\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgsproviderregistry.cpp(364) : (QgsProviderRegistry::provider) Library name is \r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgsmessagelog.cpp(41) : (QgsMessageLog::logMessage) 2013-01-28T11:41:47 [0] Failed to load : Unknown error\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgsvectorlayer.cpp(2888) : (QgsVectorLayer::setDataProvider) unable to get data provider\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgsmaplayer.cpp(104) : (QgsMapLayer::setLayerName) new name is 'Country'\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgsmslayercache.cpp(54) : (QgsMSLayerCache::insertLayer) inserting layer\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgsprojectparser.cpp(106) : (QgsProjectParser::layersAndStylesCapabilities) add layer 20130128114147107 to map\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgsvectorlayer.cpp(2722) : (QgsVectorLayer::readXml) Datasource in QgsVectorLayer::readXml: dbname='C:/OSGeo4W/apache/htdocs/qgis-web-client/data/helloworld.db' table="hello" (geometry) sql=\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\core\\qgsmaplayer.cpp(104) : (QgsMapLayer::setLayerName) new name is 'Hello'\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgsprojectparser.cpp(288) : (QgsProjectParser::addLayers) layer hello20110527130942841 not found in map - layer cache to small?\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgsprojectparser.cpp(288) : (QgsProjectParser::addLayers) layer country20110527130942817 not found in map - layer cache to small?\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgswmsserver.cpp(265) : (QgsWMSServer::getCapabilities) layersAndStylesCapabilities returned\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgshttprequesthandler.cpp(46) : (QgsHttpRequestHandler::sendHttpResponse) Checking byte array is ok to send...\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgshttprequesthandler.cpp(57) : (QgsHttpRequestHandler::sendHttpResponse) Byte array looks good, returning response...\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgshttprequesthandler.cpp(58) : (QgsHttpRequestHandler::sendHttpResponse) Content size: 4113\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgshttprequesthandler.cpp(59) : (QgsHttpRequestHandler::sendHttpResponse) Content format: text/xml\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgshttprequesthandler.cpp(67) : (QgsHttpRequestHandler::sendHttpResponse) Sent 1 bytes\r
[Mon Jan 28 11:41:47 2013] [error] [client 127.0.0.1] d:\\src\\qgis-1.8.0\\src\\mapserver\\qgis_map_serv.cpp(581) : (main) ************* all done ***************\r
Hermann
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130128/54b76202/attachment.html>
