[Qgis-user] lost 'fetch python plugins' and vector menu
Joshua Hattingh josh at rockstock.co.za
Thu Jul 4 06:57:08 PDT 2013
Hi Yes, 13.04 Raring (32-bit).
Re from terminal.  I tried typing in Qgis from the terminal and it launches
the same as from the icon.
J
On 4 July 2013 15:53, Saber Razmjooei <saber.razmjooei at lutraconsulting.co.uk
> wrote:
> If you run qgis from terminal, what error message(s) do you get?****
> *From:* Joshua Hattingh [mailto:josh at rockstock.co.za]
> *Sent:* 04 July 2013 14:52
> *To:* Saber Razmjooei
> *Cc:* Nathan Woodrow; qgis-user at lists.osgeo.org; Robert Nuske
> *Subject:* Re: [Qgis-user] lost 'fetch python plugins' and vector menu****
> Tried that, still no luck - no fetch python plugins and no openlayers
> plugin.****
> J****
> On 4 July 2013 15:42, Saber Razmjooei <
> saber.razmjooei at lutraconsulting.co.uk> wrote:****
> If you are using 1.8, I guess there is no API change for it, so the
> following should do:****
> sudo apt-get purge python-qgis****
> sudo apt-get update****
> sudo apt-get dist-upgrade****
> sudo apt-get install python-qgis****
> Just to be 100% sure!****
> Cheers****
> Saber****
> www.lutraconsulting.co.uk****
> *From:* qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org] *On Behalf Of *Joshua Hattingh
> *Sent:* 04 July 2013 14:38
> *To:* Nathan Woodrow
> *Cc:* qgis-user at lists.osgeo.org; Robert Nuske****
> Can we fix our installations? If so, how? In point form.  Do A then B then
> C etc.****
> Thanks,****
> J****
> On 4 July 2013 15:34, Nathan Woodrow <madmanwoo at gmail.com> wrote:****
> The plugin install has been merged into the plugin manager.
> The API has also chmaged so all plugins need to be updated. This is why
> you are missing some of the plugins you used to have.
> Sent from some fancy phone looking thingo****
> *From: *Joshua Hattingh
> *Sent: *4/07/2013 11:29 PM****
> *To: *Robert Nuske
> *Cc: *qgis-user at lists.osgeo.org
> *Subject: *Re: [Qgis-user] lost 'fetch python plugins' and vector menu****
> Hi Robert****
> I have the same problem (I'm trying to get Openlayers plugin but also
> don't have the "Fetch Python Plugins" menu option, and can't get help
> anywhere, been through the same methods as you.  I'm on Raring and 1.8 or
> 1.9 and same problem on both.  I've tried for 2 weeks to fix but cannot.
> Let me know if you find the secret.  There's a fix but it doesn't work for
> me.****
> Regards,****
> Josh****
> On 4 July 2013 14:38, Robert Nuske <rnuske at gwdg.de> wrote:****
> Dear QGISers,****
> somehow I have no vector menu and can not find the menu entry ****
> 'fetch python plugins'.****
> Being on Kubuntu 13.04 64bit I have my QGIS (1.8.0-2~raring1) from ****
> ubuntugis-unstable.****
> I deleted any .qgis folders, purged any qgis package and did a fresh
> install of qgis (aptitude install qgis). I have no clue what else I
> could/should try.****
> Any help is more than appreciated ****
> cheers,****
> robert****
> Additional Information:****
> $ sudo apt-cache policy qgis****
> qgis:****
> Installiert: 1.8.0-2~raring1****
> Installationskandidat: 1.8.0-2~raring1****
> Versionstabelle:****
> *** 1.8.0-2~raring1 0****
> 500 http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu/raring/main amd64 Packages
> 100 /var/lib/dpkg/status****
> 1.7.4+1.7.5~20120320-1.1 0****
> 500 http://de.archive.ubuntu.com/ubuntu/ raring/universe amd64 Packages***
> $ sudo aptitude search qgis****
> p libqgis-dev - Quantum GIS - development files ****
> p libqgis-dev:i386 - Quantum GIS - development files ****
> p libqgis1.7.5 - Quantum GIS - shared libraries ****
> p libqgis1.7.5:i386 - Quantum GIS - shared libraries ****
> i A libqgis1.8.0 - Quantum GIS - shared libraries ****
> p libqgis1.8.0:i386 - Quantum GIS - shared libraries ****
> i A python-qgis - Python bindings to Quantum GIS ****
> p python-qgis:i386 - Python bindings to Quantum GIS ****
> i A python-qgis-common - Python bindings to Quantum GIS - ar****
> v python2.7-qgis - ****
> v python2.7-qgis:i386 - ****
> i qgis - Geografisches Informationssystem (G****
> p qgis:i386 - Geografisches Informationssystem (G****
> p qgis-api-doc - Quantum GIS API documentation ****
> i A qgis-common - Quantum GIS - architecture-independ****
> v qgis-dev - ****
> v qgis-dev:i386 - ****
> p qgis-mapserver - Quantum GIS mapserver ****
> p qgis-mapserver:i386 - Quantum GIS mapserver ****
> i A qgis-plugin-globe - OSG globe plugin for Quantum GIS ****
> p qgis-plugin-globe:i386 - OSG globe plugin for Quantum GIS ****
> i A qgis-plugin-globe-common - OSG GLOBE plugin for Quantum GIS - ****
> i A qgis-plugin-grass - GRASS plugin for Quantum GIS ****
> p qgis-plugin-grass:i386 - GRASS plugin for Quantum GIS ****
> i A qgis-plugin-grass-common - GRASS plugin for Quantum GIS - arch****
> i A qgis-providers - collection of data providers to Qua****
> p qgis-providers:i386 - collection of data providers to Qua****
> i A qgis-providers-common - collection of data providers to Qua****
> p qgis-sqlanywhere - Quantum GIS sql anywhere plugin and****
> p qgis-sqlanywhere:i386 - Quantum GIS sql anywhere plugin and****
> p qgis-sqlanywhere1.7.5 - Quantum GIS sql anywhere plugin and****
> p qgis-sqlanywhere1.7.5:i386 - Quantum GIS sql anywhere plugin and****
> Qgis-user mailing list
> http://lists.osgeo.org/mailman/listinfo/qgis-user****
> This email and any files transmitted with it are confidential and intended
> solely for the use of the individual or entity to whom they are addressed.
> If you have received this email in error please notify the system manager.
> This message contains confidential information and is intended only for the
> individual named. If you are not the named addressee you should not
> disseminate, distribute or copy this e-mail. Please notify the sender
> immediately by e-mail if you have received this e-mail by mistake and
> delete this e-mail from your system. If you are not the intended recipient
> you are notified that disclosing, copying, distributing or taking any
> action in reliance on the contents of this information is strictly
> prohibited.****
> Whilst reasonable care has been taken to avoid virus transmission, no
> responsibility for viruses is taken and it is your responsibility to carry
> out such checks as you feel appropriate.****
> Saber Razmjooei and Peter Wells trading as Lutra Consulting.****
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130704/d684fbc3/attachment.html>
