[Qgis-user] SEXTANTE adaptation to new SAGA version
William Kyngesburye woklist at kyngchaos.com
Thu Jul 4 11:43:39 PDT 2013
Thanks.  This is good since only 2.1 works on OS X.
On Jul 4, 2013, at 1:37 PM, Victor Olaya wrote:
> Hi all
> SAGA 2.1.0 has just been released. The current version of SEXTANTE in
> master has been now adapted to work with SAGA 2.1.0, and raster
> algorithms will not work with any other version. Please, update your
> SAGA executables if using the latest master version, since now 2.1.0
> is the target version.
> The only algorithm adapted so far is the raster export one, which, for
> SEXTANTE, was the most important one that had been modified, since it
> blocks all other raster algorithms. Other algorithms might have
> changed, but they are not adapted yet. If you find something that was
> working before and now it doesn't, please report. Also, if there are
> new algorithms, feel free to suggest them to be added to SEXTANTE as
> well, describing their syntax, if possible, to help us do it.
> Windows users, please notice that the Osgeo4W installer still ships
> with SAGA 2.0.8, so you will need to install SAGA 2.1.0 manually and
> change the SAGA path in SEXTANTE. This will be updated soon, so it's
> just a temporary issue
> Thanks for your help
> Victor
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
