[Qgis-user] QGIS installation problem with Mac OSX 10.8.4 and some Qt4 Modules
William Kyngesburye woklist at kyngchaos.com
Sun Jul 7 09:59:56 PDT 2013
Ah, cmake installed by homebrew.  I looked at the homebrew setup for cmake, no patches that would change behavior, but I do see a different configuration setting that I don't know how it will affect cmake: --system-libs.  The default (if you install from scratch like in the QGIS install doc) is --no-system-libs.
Uninstalling homebrew GEOS and sqlite may help, but there are other things as well: PROJ in homebrew, and GEOS in /usr/local/Cellar (whatever that is).  And it's not even finding the homebrew sqlite, it's finding the system sqlite.
On Jul 7, 2013, at 11:48 AM, William Kyngesburye wrote:
> No unusual PATH stuff.
> PYTHONPATH may cause problems running any GDAL programs that are python scripts.  Though it gets added before .pth stuff, so it's probably OK.
> PROJSO is meaningless for my GDAL framework - it's only used when dynamically loading the PROJ library, my framework has it statically linked (completely different from shared vs. static library).
> So, nothing that looks like it would change cmake behavior...
Are you compiling cmake from scratch, or from homebrew?On Jul 7, 2013, at 11:48 AM, Marcel Stadelmann wrote:
> Maybe the problem lies in the GEOS or in sqlite. This two things are still in homebrew installed. Can i remove them?
> Marcels-iMac:~ Marcello$ brew list
> atk		cmake		gdbm		glib		imagemagick	libffi		little-cms2	proj
> autoconf	doxygen		gdk-pixbuf	graphicsmagick	intltool	libgeotiff	lzlib		readline
> automake	expat		geos		gsl		jbig2dec	libpng		ossp-uuid	sqlite
> bison		fontconfig	gettext		gtk+		jpeg		librsvg		pango		xz
> cairo		freetype	ghostscript	harfbuzz	latex2rtf	libtiff		pixman
> check		freexl		giflib		icu4c		libcroco	libtool		pkg-config
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am.  Or in my case - I am, therefore I ache."
- Marvin
