[Qgis-user] Error to run a model in SEXTANTE modeler
José Carlos Guerrero Antúnez
jcgantunez at gmail.com
Sun Jul 7 19:29:13 PDT 2013
I installed SEXTANTE version 1.0.8 manually.
I used Sextante Modeler to create a model to intersect two shapefiles and I
have the following error when I executed the model.
File "/Users/joseca/.qgis//python/plugins/sextante/core/GeoAlgorithm.py",
line 118, in execute self.processAlgorithm(progress)
File
"/Users/joseca/.qgis//python/plugins/sextante/modeler/ModelerAlgorithm.py",
line 408, in processAlgorithm ', '.join([str(p).strip() + "=" +
str(p.value) for p in alg.parameters]))
UnicodeEncodeError: 'ascii' codec can't encode character u'\u0301' in
position 48: ordinal not in range(128)
What is missing in the program?
QGIS 1.8
OSX 10.6.8
Many thanks,
2013/7/5 William Kyngesburye <woklist at kyngchaos.com>
> The problem is that OS X 10.6 has Python 2.6, which does not include
> importlib. This is not good if 10.6 users have to install a small
> dependency for an alternative to a basic python statement.
> On Jul 5, 2013, at 3:28 AM, José Pedro Santos wrote:
> > Hi,
> > Seems that you have missing phyton plugins. Reinstall pyhton and check
> for importlib.
> > Regards,
> > José Santos
> > From: jcgantunez at gmail.com
> > Date: Thu, 4 Jul 2013 16:51:39 -0300
> > To: qgis-user at lists.osgeo.org
> > Subject: [Qgis-user] Problems to install SEXTANTE for QGIS
> > Hi,
> > I want to install SEXTANTE 1.0.9 Plugin, but I can't, and I have this
> message: "The plugin depends on some components missing on your system. You
> need to install the following Python module in order to enable it:
> importlib"
> > How can I do it?
> > I working with QGIS 1.8, OSX 10.6.8.
> > Many thanks,
> > Dr. José Carlos Guerrero
> > Laboratorio de Desarrollo Sustentable y Gestión Ambiental del Territorio
> (LDSGAT)
> > Instituto de Ecología y Ciencias Ambientales (IECA)
> > Facultad de Ciencias
> > Universidad de la República
> > Montevideo-URUGUAY
> > _______________________________________________ Qgis-user mailing list
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "The beast is actively interested only in now, and, as it is always now
> and always shall be, there is an eternity of time for the accomplishment of
> objects."
> - the wisdom of Tarzan
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130707/5ca58d74/attachment.html>
