[Qgis-user] polygon segment
Siki Zoltan siki at agt.bme.hu
Tue Jul 9 07:55:43 PDT 2013
Dear Jake,
you can use the topological editing. In Settings/Snap options dialog
enable topological editing, check Avoid Intersections for the editing
layer and optionally set a tolerance for snapping.
After it you have to draw only the missing part of the a new polygons.
Regards,
Zoltan
On Tue, 9 Jul 2013, Jake Maier wrote:
> I want to create a new polygon and in one area it should follow the segments
> of another polygon .
> (I have a forest and want to delineate the stands.) Which plug-in can I use
> to tell the program that from here to there it should just follow an
> existing polygon either in the same shapefile (stands) or possibly in
> another shapefile (boundaries)
> Thank you for your help
> Jake
