[Qgis-user] cut several segments into a polygon
Jake Maier j.m at jmforestry.com
Tue Jul 9 08:34:45 PDT 2013
Thanks Raymond and Bernhard
I have a last question, what is the story of the md5sum. Do I also need to
download it? What is that file for?
Thanks again very much
Jake
-----Original Message-----
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Raymond Nijssen
Sent: Tuesday, July 09, 2013 11:11 AM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] cut several segments into a polygon
Jake,
It's still called 1.9 and you can download it here:
http://qgis.org/downloads/weekly/
Raymond
On 09-07-13 17:07, Jake Maier wrote:
> Hi Bernhard,
> Thanks for your help, but I'm still on 1.8 and frankly I can't find
> the place to download 2.0 for windows. I googled it several times,
> trying to find the nightlies, but I seem to get old, slow, and feeble.
> I so far was not able to get 2.0 for windows 7.
> Jake
> From: qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Bernhard
> Ströbl
> Sent: Tuesday, July 09, 2013 9:47 AM
> Hi Jake,
> I had a plugin in preparation that amongst others does exactly what
> you
> want: within an editing session cut out from polygons in editable
> theme with selected polygons from another theme.
> The plugin is called DigitizingTools and is planned to contain more
> tools in the future. I uploaded it to the plugin repository just now,
> feel free to give it a try and report any problems.
> It is marked as experimental (because it is not well tested right now)
> and only works with current master (aka QGIS 2).
> Bernhard
> Am 09.07.2013 15:11, schrieb Randal Hale:
>> Hey Jake,
>> Here's how I typically add a cut to an existing stand (or depending
>> on who you stand in front of - regeneration cut or clear cut).
>> 1. Select all of your clearcuts in the stand.
>> 2. IN the QGIS menu go to Vector -> geoprocessing -> difference 3.
>> Both the input and the difference layer will be the name of your
>> shapefile with the stand in it.
>> 4. Uncheck "Use only selected features" under Input Vector Layer 5.
>> Make sure "Use only selected features" is checked under difference
>> layer 6. Create an output shapefile and run.
>> You should have a new stand with multiple "holes" cut into it so you
>> get the right acreage.
>> Randy
>> On Tue, Jul 9, 2013 at 7:42 AM, Jake Maier <j.m at jmforestry.com
>> <mailto:j.m at jmforestry.com>> wrote:
>>      How can I create a polygon with several areas cut out. The cut out
>>      areas are all contained in polygons of the same shape file.____
>>      I have a large forest stand and contained in it are many smaller
>>      stands. ____
>>      Thank you for your help____
>>      Jake____
>>      __ __
>>      _______________________________________________
>>      Qgis-user mailing list
>>      Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>      http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Randal Hale, GISP
>> North River Geographic Systems, Inc
>> http://www.northrivergeographic.com
>> 423.653.3611 rjhale at northrivergeographic.com
>> <mailto:rjhale at northrivergeographic.com>
>> twitter:rjhale
>> http://about.me/rjhale
> __________ Information from ESET Mail Security, version of virus
> signature database 8545 (20130709) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
Terglobo
Ampèrestraat 110
5223 CT 's-Hertogenbosch
06-25314983
