[Qgis-user] [Plugin presentation] LayerCombination
kimaidou kimaidou at gmail.com
Wed Jul 17 00:39:50 PDT 2013
This is huge ! Thanks for this plugin. I think this should definitely be
added as a core plugin (in 2.1) if other agree, of course
Michael
2013/7/17 Stott James <fmrojst at fylkesmannen.no>
>  Man I wish this had existed about a year and a half ago. Especially the
> fact that it integrates into the composers too. I have always felt that was
> something that was needed – an easy way to edit the locked layers in a
> composer map – hence why I wrote a plugin for it.****
> Think I may well not bother update the locked layers editor plugin to 2.0
> seeing as you have made this. This is much better.****
> James****
> *Fra:* qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org] *På vegne av* Lene Fischer
> *Sendt:* 17. juli 2013 04:41
> *Til:* Olivier Dalang
> *Kopi:* qgis-user; qgis-developer at lists.osgeo.org
> *Emne:* Re: [Qgis-user] [Plugin presentation] LayerCombination****
> Wauuh****
> What a plugin. Can't wait to use it. My studens work on big projects with
> many layers from differe nt timeperiods. This will help !****
> Good idea with the small video.****
> Regards****
> Lene Fischer****
> Sendt fra min iPad****
> Den 17/07/2013 kl. 01.51 skrev "Olivier Dalang" <olivier.dalang at gmail.com
>  Dear Mailing list, ****
> I've been working on a python plugin called "Layer Combinations", which
> I'd love to release as stable for QGIS 2.0 (it's still flagged as
> experimental).****
> Since it's a workflow enhancement plugin, I thought it could be of some
> interest to most of you. If so, I invite you to try the latest version
> (0.8, requires QGIS nightly/master), and report any bugs or ideas on the
> tracker :****
> https://github.com/olivierdalang/layerCombinations****
> You'll find a small explanation of the plugin below, and a video trailer
> here :****
> https://vimeo.com/70446444****
> Thanks for your attention !****
> Olivier****
> ## LayerCombinations##****
> It allows to store the visibility and the folding state of the layers in
> the legend in so called "combinations".****
> Those combination can then be restored, allowing to switch back and forth
> complex setups.****
> The combinations can also be applied to composer maps. The link is
> dynamic, which means that if the combination is updated, the composer map
> will automatically reflect the modifications.****
> I find it very handy for big projects with many layers and several print
> composers.****
> Hope you like it !****
>  _______________________________________________
> Qgis-user mailing list
> http://lists.osgeo.org/mailman/listinfo/qgis-user****
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130717/1c653fd1/attachment.html>
