[Qgis-user] Proyection cuestion?
Raúl Nanclares raulnanclares at gmail.com
Wed Jul 17 12:41:29 PDT 2013
Hola Roberto,
Vector:
to do projection transformations you just have to select the vector layer ,
"save as" then choose the projection you want to use and save it (with a
different name). When you load the layer check i you have the project set
to the right reference system for the layer in the Settings / Project
Properties menu. If you check the 'On the Fly CRS transformation' checkbox
any layer that you load will be instantly reprojected to the CRS set for
the project, but then you will have to save this layers with the new CRS to
'reproject' them.
Raster:
Go to Raster/ Projections / Warp.
Hope it helps.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130717/9bee55bd/attachment.html>
