[Qgis-user] QGIS rotate entire rendered map
Andreas Neumann a.neumann at carto.net
Sat Jul 20 03:17:53 PDT 2013
Hi Bjorn,
This is not possible currently. The workarounds that Paolo and Raymond
suggested are not what you want. Raymonds suggestion only concerns
printed output and Paolos suggestion transforms the data, which is also
not what you want.
You can open a feature request for this for QGIS 2.1. QGIS 2.0 is in
feature freeze already. Best would be if you can hire a developer to
develop it or code it yourself. It may even cost less than your annual
ArcGIS maintenance fee to develop this missing feature (but this is just
a wild guess).
Andreas
Am 20.07.2013 12:01, schrieb Bjorn Nyberg:
> Hej,
> I am slowly trying to move away from arcgis to open source software like grass
> and qgis but there is one feature that I really like in arcgis that I cant seem
> to find in QGIS in my transition. Simply enough, i'd like to rotate all layers
> in the current rendered window to say 90degrees relative to north as I map a
> feature (note I am not talking about rotating the final map output as suggested
> here
> http://gis.stackexchange.com/questions/54060/can-qgis-1-8-0-mac-rotate-the-entire-view-of-a-project).//I
> use this feature quiet a lot in arcgis (data frame properties -- general --
> rotation) to map especially elongated feature at a resolution that otherwise
> won't fit on my screen and I assume that there must be something equivalent in
> qgis that I have simply not noticed.
> Cheers,
> Bjorn
> <cid:part2.04070703.02020502 at gmail.com>
> Qgis-user mailing list
