[Qgis-user] QGIS Android: can't see files on nexus 7
Raúl Nanclares raulnanclares at gmail.com
Fri Jul 26 11:31:28 PDT 2013
Hi Mateo, if i recall correctly, the problem is you can't see the folder
QGIS is using because it's hidden.
Try this:
When you click on the 'browse' button, in the menu that opens after you
click on add vector, use the 'up arrow' to navigate through the system
folders. Eventually you will reach the / folder, click again on the 'up
arrow' and you will see several folders, click on /sdcard, you should be
able to open any file stored in those folders.
Hope it helps.
Cheers.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130726/fc5c8805/attachment.html>
