[Qgis-user] Fetch plugins missing
Borys Jurgiel lists at borysjurgiel.pl
Thu Jun 27 10:15:06 PDT 2013
So seems the installer is on board. Could you please take a look at the log
console as well (The "!" icon in lower-right corner or in
Settings->Panels->Log messages menu)? In the Plugins tab you should see just
"Loaded Plugin Installer (package: plugin_installer)" message.
If everything there is ok, probaby the error you reported may have something
to do with it... It shows a problem with addidng a menu entry, however, it
looks rather like the "Project properties" entry is going to be inserted
twice. I never met such problem anyway and I'm afraid I have no idea what is
the reason.
You can also try to clear the configuration, by removing (or temorarily
renaming the two directories: ~/.qgis and ~/.config/QuantumGIS
