[Qgis-user] Coordinate Geometry capability
Olivier Dalang olivier.dalang at gmail.com
Mon Mar 4 09:40:33 PST 2013
I'm not sure I understood you need well, but there's the "Improved Polygon
Capturing" plugin, which allows to enter the distance numerically.
I developed an update to this plugin which now allows to enter the angle
numerically also (CAD-like drawing).
Unfortunately, it's still not in the plugin repo since I'm not the original
author. But in the mean time, you can find it here :
https://github.com/olivierdalang/improvedpolygoncapturing
Cheers,
Olivier
2013/3/4 David Fawcett <david.fawcett at gmail.com>
> There is a COGO plugin for QGIS called Azimuth and Distance.  I haven't
> tried it, but Randy Hale wrote a blog post about it last spring.
> http://www.northrivergeographic.com/archives/lost-my-bearing-found-it-in-qgis
> David.
> On Mon, Mar 4, 2013 at 10:54 AM, Gerard Ashton <ashtongj at comcast.net>wrote:
>> ArcEdit includes functionality that land surveyors like to call coordinate
>> geometry.
>> One can start at a given coordinate, and enter the direction and lengths
>> of
>> line
>> segments on a traverse. The traverse usually returns to the point of
>> beginning.
>> Once the traverse is entered, calculations may be performed to find
>> distance
>> and direction between any two points, or the area enclosed by the traverse
>> may be calculated. Naturally one might want to combine this with shape
>> files
>> for comparison.
>> Of course optimum results in this area would be provided by an expensive
>> software package marketed to land surveyors. But does Quantum GIS
>> have reasonable capabilities in this area?
>> I am new to free GIS software and am exploring what might be best. I
>> have used various ESRI software in the past that I had free access to,
>> but at present, don't have a revenue stream that would support the
>> purchase of ESRI software.
>> I am not a land surveyor or GIS professional; I have done fairly simple
>> map making for various fire, EMS, and disaster organizations that I
>> volunteer with.
>> Gerard Ashton
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130304/97edb3f9/attachment.html>
