[Qgis-user] Composer and transparency
Pedro Venâncio pedrongvenancio at yahoo.com
Mon Mar 4 15:57:35 PST 2013
Hi Cascafico,
I have also a problem with Composer on QGIS 1.8. When I use rasters with transparency along with other layers, some horizontal stripes appear without transparency.
Normally I make the union of MDT with Shaded Relief. To combine the MDT with the Shaded Relief, I use the r.his function, placing the MDT as HUE and Shaded Relief as Intensity, resulting in a set of three rasters corresponding to the three RGB channels. Then I use r.composite to create the final RGB image.
Best regards,
Pedro Venâncio
To: qgis-user at lists.osgeo.org
Sent: Monday, March 4, 2013 10:46 AM
Subject: [Qgis-user] Composer and transparency
Hello valuable list!
Qgis composer has a known bug in managing raster layers with  transparency.
So I need a workaround to merge rgb relief with single band DEM.
Is there a pret-a-porter expression for raster calculator?
Or I need to convert rgb to hsv before? If so,  how?
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
