[Qgis-user] Map graticules in QGIS
Lester Anderson arctica1963 at gmail.com
Sun Mar 10 15:13:10 PDT 2013
Hello,
The one major element missing from the otherwise great Quantum GIS, is that
of easy setup map graticules. There is a basic way of doing simple ones in
the print composer which is fine for geographic (WGS84) or UTM etc type
projections, but will not work for conic or stereographic etc.
Is there a plugin for doing this work (that is built-in to layout mode in
ArcGIS) or is this an upgrade/update that will be available in a new
release?
Generating a vector grid does not work properly in 1.8.0, and certainly
only partially completes a Polar Stereographic layout. There are clearly
flaws that need to be addressed. If there is a reliable workaround for
this, it would be good to know.
Lester
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130310/c604764c/attachment.html>
