[Qgis-user] Creating a square buffer area around a point
Andy Harfoot ajph at geodata.soton.ac.uk
Tue Mar 12 07:26:20 PDT 2013
If you run the 'Fixed distance buffer' tool from the Sextante QGIS
algorithms toolbox with a segment count of 1, then you will generate a
square polygon around each point. You may then need to rotate them by
45° to align with the coordsys axes if required.
Note that you have to use the Sextante version of the buffer command as
the Vector > Geoprocessing Tools > Buffer command won't allow a segment
count of less than 5 (maybe this restriction should be dropped?)
Cheers,
Andy
Luisa Peña wrote:
> Dear all,
> I have a point (from a shapefile) and I need to create a squared
> buffer, centered on my point with a distance of 30 kms. How can I do
> this in QGIS?
> Thanks
> Regards,
> Luisa
> Qgis-user mailing list
Andy Harfoot
GeoData Institute
University of Southampton
Southampton
SO17 1BJ
Tel:  +44 (0)23 8059 2719
Fax:  +44 (0)23 8059 2849
www.geodata.soton.ac.uk
