[Qgis-user] DD to meters
adamu eloji aeloji60 at yahoo.com
Fri Mar 15 05:09:06 PDT 2013
Dear All,
             How can Decimal  Degree be converted to meters.Any idea from member.
Thanks
Adamu
 From: "qgis-user-request at lists.osgeo.org" <qgis-user-request at lists.osgeo.org>
To: qgis-user at lists.osgeo.org
Sent: Wednesday, March 13, 2013 3:38 PM
Subject: Qgis-user Digest, Vol 85, Issue 31
Send Qgis-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
    http://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
    qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Qgis-user digest..."
Today's Topics:
   1. Re: convert UTM_UPS data from gps to decimal degrees
      (Bernd Laskowski)
   2. Re: convert UTM_UPS data from gps to decimal degrees (G. Allegri)
Message: 1
Date: Wed, 13 Mar 2013 15:28:32 +0100
From: Bernd Laskowski <Bernd.Laskowski at Reichshof.de>
Subject: Re: [Qgis-user] convert UTM_UPS data from gps to decimal
    degrees
Message-ID: <51408D10.2090603 at Reichshof.de>
Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
I tryed again with milliseconds but the result is nearly the same.
The real Point is about 80 km away.
The UTM UPS WGS84 koordinate system seems to be another than usual WGS84.
Regards
Bernd
Am 13.03.2013 14:49, schrieb G. Allegri:
> I'm not sure if they are milliseconds.
> O would try to divide the last digits by 3600000 (and sum to the rest)
> 2013/3/13 Bernd Laskowski <Bernd.Laskowski at reichshof.de
> <mailto:Bernd.Laskowski at reichshof.de>>
>     Hi Giovanni,
>     If I try this the points are fare away from the real point.
>     What about the Number rigth from seconds (f.e. 2 or 9)?
>     Regards
>     Bernd
>     Am 13.03.2013 14:09, schrieb G. Allegri:
>>     degrees+minutes/60+seconds/3600
>>     e.g.
>>     50+(96/60)+(6/3600) = 51.601666...
>>     giovanni
>>         Hi all,
>>         how I can convert data in following format to get decimal
>>         degrees.
>>         50?96'06''2N/7?70'18''3O
>>         50?96'39''9N/7?68'56''3O
>>         50?95'72''9N/7?68'00''5O
>>         Garmin GPS configuration:
>>         Positionsformat: UTM UPS
>>         Kartenbezugssystem: WGS84
>>         Kartensph?roid: WGS84
>>         Would WGS84/UPS North (EPSG 32661) in Qgis the correct
>>         coordinate system?
>>         I use ETRS89 (EPSG 25832)
>>         Regards
>>         Bernd
>>         _______________________________________________
>>        Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>     Giovanni Allegri
>>     website: http://giovanniallegri.it <http://giovanniallegri.it>
>>     GEO+ geomatica in Italia http://bit.ly/GEOplus
>     Gemeinde Reichshof
>     I/10 Zentrale Verwaltung
>     Bernd Laskowski
>     Hauptstra?e 12
>     51580 Reichshof - Denklingen
>     Tel.: (02296) 801 - 313
>     Fax: (02296) 801 - 395
>     E-mail:Bernd.Laskowski at Reichshof.de  <mailto:Bernd.Laskowski at Reichshof.de>
>     Der Inhalt dieser E-Mail ist ausschlie?lich f?r den bezeichneten Adressaten bestimmt. Wenn Sie nicht der vorgesehene Adressat dieser E-Mail oder dessen Vertreter sein sollten, so beachten Sie bitte, dass jede Form der Kenntnisnahme, Ver?ffentlichung, Vervielf?ltigung oder Weitergabe des Inhalts dieser E-Mail unzul?ssig ist. Wir bitten Sie, sich in diesem Fall mit dem Absender der E-Mail in Verbindung zu setzen.
>     Bei Abwesenheit des Adressaten, an den Sie eine E-Mail gerichtet haben, kann diese automatisch an dessen Vertreter weitergeleitet werden. Wir m?chten Sie au?erdem darauf hinweisen, dass die Kommunikation per E-Mail ohne Authentifizierung und Verschl?sselung unsicher ist, da f?r unberechtigte Dritte grunds?tzlich die M?glichkeit der Kenntnisnahme und Manipulation besteht. Wir ?bernehmen deshalb keine Verantwortung f?r den Inhalt dieser Nachricht, da eine Manipulation nicht ausgeschlossen werden kann. Obwohl wir alle angemessenen Vorkehrungen getroffen haben, um sicherzustellen, dass Anlagen dieser E-Mail Virus-gepr?ft sind, empfehlen wir dennoch, anh?ngende Dateien vor dem ?ffnen durch Ihr eigenes Virus-Programm zu pr?fen, da wir keinerlei Haftung f?r Sch?den ?bernehmen, die infolge etwaiger Software-Viren entstehen k?nnten.
> Giovanni Allegri
Gemeinde Reichshof
Bernd Laskowski
Hauptstra?e 12
E-mail: Bernd.Laskowski at Reichshof.de
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130313/258fcdbb/attachment-0001.html>
Message: 2
Date: Wed, 13 Mar 2013 15:38:27 +0100
To: Bernd Laskowski <Bernd.Laskowski at reichshof.de>
Cc: qgis-user at lists.osgeo.org
    degrees
Message-ID:
    <CAB4g1=z8AfAnD+_3cV666jZia0iUjNi-wr9uG4b+RtSdgCnAcg at mail.gmail.com>
UTM/UPS are prjections which can be used to translate WGS84 lat/lon
coordinates to planar coordinates.
UTM is used for latitudes upt to 80 deegree (more or less), while UPS
(North/South) are used for higher latitudes, polar regions.
Coordinates in UTM/UPS would be metrics, while you're reporting lat/lon
coordinates, which should be the WGS84 raw coordinates from the GPS.
What is the CRS of the base map tou're using to test the correctness of the
coordinates?
2013/3/13 Bernd Laskowski <Bernd.Laskowski at reichshof.de>
> Regards
> Bernd
>>  Hi Giovanni,
>> Regards
>> Bernd
>>  e.g.
>>  giovanni
>>>  Hi all,
>>> how I can convert data in following format to get decimal degrees.
>>> Would WGS84/UPS North (EPSG 32661) in Qgis the correct coordinate system?
>>> Regards
>>> Bernd
>> Giovanni Allegri
>> Gemeinde Reichshof
>> Bernd Laskowski
>> Hauptstra?e 12
> Giovanni Allegri
> Gemeinde Reichshof
> Bernd Laskowski
> Hauptstra?e 12
Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130313/e34b6b50/attachment.html>
End of Qgis-user Digest, Vol 85, Issue 31
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130315/f1262e75/attachment.html>
