[Qgis-user] create 3d shapefile and/or GPX
Agustin Lobo alobolistas at gmail.com
Sat Mar 16 12:06:14 PDT 2013
Martin,
Merci!
Very interesting material!
Agus
On Sat, Mar 16, 2013 at 1:59 PM, gene <martin.laloux at gmail.com> wrote:
> Yes, in the Python console using other Python modules like Shapely but it is
> even easier to do it directly in Python without QGIS:
> *In the Python console of QGIS*
> see  QGIS, visualización 3D de capas vectoriales con Python
> <http://geotux.tuxfamily.org/index.php/en/geo-blogs/item/315-qgis-visualizacion-3d-de-capas-vectoriales-con-python>
> (in Spanish) or  QGIS, représentation 3D des couches vectorielles
> (shapefiles dits 3D ou shapefiles avec attributs z) avec les modules Python
> Matplotlib ou Visvis à partir de la console Python
> <http://www.portailsig.org/content/qgis-representation-3d-des-couches-vectorielles-shapefiles-dits-3d-ou-shapefiles-avec-attrib>
> (in French) or  Is there are QGIS plugin to allow the 3d visualisation of
> geological borehole data similar to the functionality of Target for ArcGIS?
> <http://gis.stackexchange.com/questions/41701/is-there-are-qgis-plugin-to-allow-the-3d-visualisation-of-geological-borehole-da/41719#41719>
> it shows how to read 3D Shapefiles or taking the z coordinate from a column
> in the table. Create a 3D shapefile is just as easy.
> *Directly in Python*
> With modules like Shapely, ogr or Pyshp, see for example
> http://code.google.com/p/pyshp/wiki/CreateElevationValues
> <http://code.google.com/p/pyshp/wiki/CreateElevationValues>  .
> You can even take the z values from a DEM (see
> http://www.portailsig.org/content/python-utilisation-des-couches-vectorielles-et-matricielles-dans-une-perspective-geologique-
> <http://www.portailsig.org/content/python-utilisation-des-couches-vectorielles-et-matricielles-dans-une-perspective-geologique->
> , in French)
> Python can do everything ....
> View this message in context: http://osgeo-org.1560.n6.nabble.com/create-3d-shapefile-and-or-GPX-tp5040855p5040863.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
