[Qgis-user] QGIS install fail on Ubuntu 12.04
José Pedro Santos zpsantos1 at hotmail.com
Mon Mar 18 09:06:04 PDT 2013
is better to uninstall QGIS from your machine. Try to install by the Ubuntu Software or Synaptic Package. Alternative chek the package name of the plugin and install it with the synaptic package.
Did you install Ubuntu GIS packages?
Regards,
José Santos
Date: Mon, 18 Mar 2013 11:58:45 -0400
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] QGIS install fail on Ubuntu 12.04
I had QGIS working on 12.04 this morning. Unfortunately, I did not have the option to "fetch python plugins." I played around with a few different things trying to get it to work to no success. After some reading, it appeared I needed the python-qgis package. I tried to install this package, but missing dependencies prevented installation.
Instead, I completely purged qgis and attempted to reinstall through terminal as outlined here: http://hub.qgis.org/projects/quantum-gis/wiki/Download#26-Ubuntu.
At this time, I'm receiving the following errors.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 qgis : Depends: qgis-providers (= 1.8.0-1~precise3) but 1.9.0+git20130316+5d42734~precise1 is to be installed
        Depends: qgis-common (= 1.8.0-1~precise3) but 1.9.0+git20130316+5d42734~precise1 is to be installed
        Recommends: qgis-plugin-globe but it is not going to be installed
        Recommends: qgis-plugin-grass but it is not going to be installed
        Recommends: python-qgis but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
I was able to install QGIS (with python plugins) on a fresh 12.04 install on my laptop last night with no problems. I'm not sure what's causing the issue here.
Please advise.
All the best,
Lee
ISA Certified Arborist MI-4148A
Registered Forester #46043
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130318/31a99af5/attachment.html>
