[Qgis-user] QGIS install fail on Ubuntu 12.04
Lee muellerl at gmail.com
Tue Mar 19 08:37:34 PDT 2013
Gang,
I was able to use the process linked by Alex to downgrade to Precise
stable, rather than precise proposed. However, after following those
directions I received a series of errors related to CUPS. After some
searching, I used the following process:
http://ubuntuforums.org/showthread.php?t=1856911 to fix those errors. Once
everything worked, I installed qgis from the terminal. Everything now
appears to be working.
Thank you.
All the best,
Lee
ISA Certified Arborist MI-4148A
Registered Forester #46043
On Mon, Mar 18, 2013 at 9:38 PM, Alex Mandel <tech_dev at wildintellect.com>wrote:
> You need to take several steps back.
> My suspicion, and likely no fault of your own, precise-proposed repos are
> turned on. The hint is that qt of this version (4:4.8.1-0ubuntu4.2) is only
> in precise-proposed.
> So to unstick the system you're going to have rollback all packages that
> came from proposed, and stick to precise-security and precise-updates. Not
> proposed or backports. If you do that then you should be able to get it all
> working as expected.
> Longer explanantion, QGIS is built against the main ubuntu repos, not the
> proposed repo which can shift versions unexpectedly. Your other option here
> is to compile it yourself against whatever versions you have, but even that
> might not work if qt is too new and doesn't work with the python you have.
> This link demonstrates the concept:
> http://ubuntuforums.org/**showthread.php?t=432636<http://ubuntuforums.org/showthread.php?t=432636>
> Good Luck,
> Alex
> On 03/18/2013 01:03 PM, Lee wrote:
>> On attempting to manually install qt4 through the software center, the
>> following error is generated:
>> Package dependencies cannot  be resolved
>> This error could be caused by required additional software packages which
>> are missing or not installable. Furthermore there could be a conflict
>> between software packages which are not allowed to be installed at the
>> same
>> time.
>> The following packages have unmet dependencies:
>> python-qt4: Depends: python (< 2.8) but 2.7.3-0ubuntu2 is to be installed
>>              Depends: libgcc1 (>= 1:4.1.1) but 1:4.6.3-1ubuntu5 is to be
>> installed
>>              Depends: libqt4-dbus (>= 4:4.8.0-1~) but 4:4.8.1-0ubuntu4.2
>> is
>> to be installed
>>              Depends: libqt4-declarative (>= 4:4.8.0-1~) but
>> 4:4.8.1-0ubuntu4.2 is to be installed
>>              Depends: libqt4-designer (>= 4:4.8.0-1~) but 4:4.8.1-0ubuntu4
>> is to be installed
>>              Depends: libqt4-help (>= 4:4.8.0-1~) but 4:4.8.1-0ubuntu4 is
>> to
>> be installed
>>              Depends: libqt4-network (>= 4:4.8.0-1~) but
>> 4:4.8.1-0ubuntu4.2
>> is to be installed
>>              Depends: libqt4-script (>= 4:4.8.0-1~) but 4:4.8.1-0ubuntu4.2
>> is to be installed
>>              Depends: libqt4-scripttools (>= 4:4.8.0-1~) but
>> 4:4.8.1-0ubuntu4 is to be installed
>>              Depends: libqt4-svg (>= 4:4.8.0-1~) but 4:4.8.1-0ubuntu4.2 is
>> to be installed
>>              Depends: libqt4-test (>= 4:4.8.0-1~) but 4:4.8.1-0ubuntu4 is
>> to
>> be installed
>>              Depends: libqt4-xml (>= 4:4.8.0-1~) but 4:4.8.1-0ubuntu4.2 is
>> to be installed
>>              Depends: libqt4-xmlpatterns (>= 4:4.8.0-1~) but
>>              Depends: libqtcore4 (>= 4:4.8.0-1~) but 4:4.8.1-0ubuntu4.2 is
>> to be installed
>>              Depends: libqtgui4 (>= 4:4.8.0-1~) but 4:4.8.1-0ubuntu4.2 is
>> to
>> be installed
>>              Depends: sip-api-8.1 but it is a virtual package
>> All the best,
>> Lee
>> On Mon, Mar 18, 2013 at 3:37 PM, Andre Joost <andre+joost at nurfuerspam.de>
>> **wrote:
>>  Am 18.03.2013 19:57, schrieb Lee:
>>>   In general, the error messages are generated upon launch of QGIS. I
>>> cannot
>>>> even get to a point where I have the option of installing plugins. There
>>>> is
>>>> no option to "fetch python plugins."
>>> Yes, this is a follow.up to the missing python package.
>>> Try this:
>>> Open Ubuntu software center
>>> Edit -> Software package sources
>>> "Other Software" tab
>>> There should be two entries for ubuntugis-unstable (and nothing from
>>> ubuntugis-stable)
>>> close the window
>>> click on "AllSoftware", and enter qt4 in the search field
>>> You should have installed python-qt4 4.9.1-2ubuntu1
>>> If not, you should do it manually.
>>> click on the dropdown box next to "All Software", and select
>>> ubuntugis-unstable. You should have QGIS, and a note that 177 files are
>>> hidden. Click on that link. You should get a list of all packages from
>>> ubuntugis, including python-qgis. Clicking on that, you should get
>>> information on the version python-qgis 1.8.0-1~precise3, and if it is
>>> installed or not.
>>> Greetings,
>>> André Joost
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130319/677e8945/attachment.html>
