[Qgis-user] Strange behavior selecting features - Map canvas pans to its center
Alexandre Neto senhor.neto at gmail.com
Wed Mar 20 07:50:25 PDT 2013
Problem solved.
After analyzing the qgs file I realized that the behavior was a result of
using the ItemBrowser plugin.
Alexandre Neto
On Wed, Mar 20, 2013 at 1:11 PM, Alexandre Neto <senhor.neto at gmail.com>wrote:
> I'm having this strange behavior in a project:
> While using a specific postgis layer, when selecting a feature, the map
> canvas automatically pans to the feature "center". If I load the same layer
> again, the problem does not happens with the new layer.
> Is it some option that I might have chosen? Can't really figure it out
> I'm using QGIS 1.8.0 f440b60, in windows 7 64 bit, installed using
> OSgeo4w. Opening the same project in 1.9 also have the same behavior
> Obviously I can always open the layer again, but I was trying to
> understand what happened...
> Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130320/66947c83/attachment.html>
