[Qgis-user] Field Calculator calculates negative area
magerlin MAP at ramboll.dk
Mon Mar 25 08:31:30 PDT 2013
Hi Stefan
You're right - I had not noticed the 10 digit limit.
But since you can not set it higher I had to calculate area as square
kilometers instead and got the right number.
Perhaps Qgis should give some kind of warning - it was only because of the
negative number I noticed it, had it been positive I might not have
noticed...
Regards Morten
Qgis 1.8.0 Stand alone installer in Win7 64 bit
View this message in context: http://osgeo-org.1560.n6.nabble.com/Field-Calculator-calculates-negative-area-tp5042754p5042763.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
