[Qgis-user] Label with HTML-expressions
Andreas Neumann a.neumann at carto.net
Tue Mar 26 01:36:23 PDT 2013
 Are you using QGIS 1.8 or QGIS 1.9x? As far as I know this only works
 in 1.9x (master version).
 Andreas
 On Tue, 26 Mar 2013 07:49:15 +0000, Lene Fischer wrote:
> I´ve tried to insert a HTML  in the label-expression.
> The url in coloumn 'www'
> 'link [1]'
> The output example looks like a link (blue and underline), but when I
> look at the map - it is filled with non interpreted text.
> Is there a "render as HTML" label option I have overlooked?
> Regards
> Lene Fischer
> Links:
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
